Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 10-21-2003, 07:51 PM
hmorder hmorder is offline
Garage is empty, add now
hmorder is starting off with a positive reputation.
Lightbulb propane full time!
I just got word of this from my performance guy that did my propane system. He said that he's going to have a system worked out soon that will give you the option to run propane at a 13-25% rate mixed with the diesel full time (of course you could switch this back to normal operation with a switch and you would still have another switch for the regular propane injection boost). Anyways with this percentage running on the system an F-350 longbed can be expected to have 24 mpg and a boost of about 20, maybe 30 horsepower. Of course this uses propane for which he has a bigger tank that will install opposite the fuel tank undercarriage with a fill nozzle back by the license plate....I will get this the second he gives me the thumbs up on it. Anybody else heard of this?
  #2 (permalink)
Old 10-21-2003, 08:16 PM
Jlower's Avatar
Jlower Jlower is offline
Jlower is starting off with a positive reputation.
You might want to ask Quadzilla on this one. He pointed me to a cool system he uses called "Powershot 2000". So far everything I've read about the system is astounding! I've already started my penny jar to save up for one.
What say you Quadzilla?
__________________
03 F-350 CC LB Lariat 7.3 PSD 4X4 DRW/ Plenty O' goodies---Dare to race ?
SIGINT/ELINT - In God we trust, all others we monitor.
  #3 (permalink)
Old 10-22-2003, 01:59 PM
Quadzilla's Avatar
Quadzilla Quadzilla is online now
Quadzilla is gaining momentum as a positive member of FTE.Quadzilla is gaining momentum as a positive member of FTE.
The system I have enables you to adjust the propane flow so it comes on as soon as you get measurable boost. I don't think a propane system would work very well if it was on all the time, because the truck won't idle. (Trust me on this, I tried.) When using propane to reduce diesel comsumption, you reach a point where one of two things happen as you increase the propane: you either get pre-detonation which will destroy your engine, or the cost of the propane exceeds the savings in diesel fuel. Granted, propane can/will reduce your fuel consumption, but if you go to far, neither of the options is good.
__________________
When you're walking away from your truck, do you turn around just to look at it? Yeah, so do I. ☺
'13 F-250 Platinum CC SB 4X4 Powerstroke.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
