Head removal questions/tricks
You do have the plugs removed? Beyond that, the big pry bar is already more agressive than most of us would try. I'd pull any plugs, pull the manifold if not already, get soem good penetrating lube, tap the ends (any non-sealing surface area) lightly with a hammer, repeat as necesary. Then use a screw driver gently at the ends if needed.
There are indentions on the bottom of the head about 1/3 of the way from each end. They are made for sticking a prybar in and I have never had a problem getting any heads off. Find a picture of some FE heads online that show the bottom and you will know what I am talking about.
Edit: Just did some looking around and some have the prybar slots in close to the center. Including the C8AE-H. My D2TE-AA heads had them spaced as stated above.
I remember prying on a set of junk heads in the junkyard for about 45 minutes one day and I couldn't get the heads off this rusty FE. I was beating them like crazy becasue all I wanted them for was to practice porting so I wasn't trying to be careful. I went and got one of those "bigger than you would ever need for a screw" screw drivers and pounded it into the little slot there. The head came right off.
You all are the best!
I was actually trying to pry up under the exhaust manifold as to not damage the head. The little info about the slot is where I'm heading next. I tapped a set off before with no problem, but wedged the srewdriver under a tab that was on the front face of the head. Thinking that only works for the driver side though, as the passenger side would have that in the back of the motor. I found some pristine D2's in the yard and all the bolts removed without a hitch! $50 spent will be well saved in agrevation and tools to remove the broken studs in my other heads
--Mike G
--Mike G
john fin
01-09-2020 10:19 AM
Andywk
02-26-2005 04:32 PM
