How to read the tag on a Ford 8.8" Rear - Ford Truck Enthusiasts Forums
Old 12-22-2000, 07:47 PM
95xltmud 95xltmud is offline
95xltmud is starting off with a positive reputation.
I have a 1995 Ford F-150 4x4 XLT, and I am looking into purchasing a posi for my rear, but I need to know the spline count before i an order. How to I figure this out. This is what my tag on the rear says
S832J
3 31 88 5C13
I assume that the 88 means 8.8" rear, does the 31 mean 31 spline? or is the 31 linked with the other 3 to the left of it meaning that i have 3.31 gears? That is what i originally thought it meant, but since the first 3 is spaced so far away from the 31, I am thinking that maybe they arent connected and that the 31 means 31 spline, can someone help?
Old 12-23-2000, 12:14 AM
nate512 nate512 is offline
nate512 is starting off with a positive reputation.
i'd say so -- when i talked to Ford Parts about this (was looking into getting a different ratio) i was told 4x4 trucks use 31 spline...
28 is probably for cars??
-nt
Old 12-23-2000, 12:28 AM
cgl cgl is offline
cgl is gaining momentum as a positive member of FTE.
The 3 31 means you have a 3.31 gear in that rear end. The space is for a L, which would make it a limited slip rear end. My rearend has a 3L55 which is a limited slip 3.55, but my friends is just a 3 55.
The trucks have a 31 spline axle, cars use the 28 spline.
Old 12-23-2000, 12:47 AM
PAUL_2 PAUL_2 is offline
PAUL_2 is starting off with a positive reputation.
Old 12-23-2000, 12:04 PM
Ok, thanks alot. The helps me out so much because now I know that my truck doesnt have a limited slip because I had heard from a few other sources that it might. Thanks alot.
-John
Differential question. FlaresideF150 1987 - 1996 F150 & Larger F-Series Trucks 4 02-23-2013 02:56 PM
31 spline rear bob_351 1961 - 1966 F-100 & Larger F-Series Trucks 2 03-05-2011 03:24 PM
28 spline to 31 spline Madmike33 Clutch, Transmission, Differential, Axle & Transfer Case 4 07-25-2008 09:59 PM
rear end 9.75" - how many splines by axleshaft?? YOMAN 2004 - 2008 F150 1 11-22-2004 02:24 AM
28, 30, or 31 Splines on my Pinion Shaft hl649 Ford Inline Six, 200, 250, 4.9L / 300 4 07-22-2002 01:50 AM
Tags
2000, 28, 31, 331, 355, 55, 88, end, f150, ford, read, reading, rear, s832j, spline, tag
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
