460 Ignition Problem - Ford Truck Enthusiasts Forums
Old 12-04-2000, 09:47 PM
shortk shortk is offline
shortk is starting off with a positive reputation.
My 1987 Class C motorhome on an E-350 chassis with a 460 has developed a problem I cannot identify, but it seems like a timing problem to me. I usually set the cruise control at about 65mph and it runs along quite well, but the last trip I would occasionally get a small backfire, that I could hear, but not feel, just a little "pop". Also, once when passing a line of semi trucks, I kicked it up to about 72mph to get around them and all of a sudden it just starting slowing down. The motor sounded smooth, just no power. I was about to jump in my Ranger I was towing and PUSH the motorhome! It dropped down to about 55, and I fell in behind the truck to let other traffic pass, and it would then accelerate and I passed the truck at about 75 or better after that. Power on the hills has dropped too, but it seems ok sometimes. I first thought it was a fuel problem, but I changed the filter and checked flow out of the fuel line and it looks good. The timing at an idle is fine, the mechanical advance seems to be working, but doesn't the Dura-spark module control timing too? Of all the Fords I've owned, the only problem I've had with a Dura-spark was no spark at all not an intermittant problem like this.
Any help would be appreciated.
Ken
90 Ranger 4X4
91 Explorer 4X4
94 F-150 4X4
87 Ford Moho (ailing)
Old 12-05-2000, 11:34 PM
jakegypsum's Avatar
jakegypsum jakegypsum is offline
jakegypsum is starting off with a positive reputation.
Ken, have you tuned the engine up lately? It could possibly be a cracked ignition wire or boot right where the wires go to the plugs. The heat from the exhaust manifold could have dried the wires out. Also check coil. Make sure that there are no cracks in it and that it is sending a blue spark to the plugs. I have had similar problems with wires on my 92' f-250 (351 engine). I have seen the coil act up like this on all of my f-700's at one point or another. 84', 86' 87' & 89'.370 engine. Also check wiring to distributer for chaffing on engine block. Good luck.... Jakegypsum // Ford fleet, soup to nuts.
When the wind is right, you can hear those Chevy's rust..........just listen.
Old 12-21-2000, 06:45 PM
homeonwheels homeonwheels is offline
homeonwheels is starting off with a positive reputation.
I had a vacuum leak going to my vacuum advanced that caused a very simular problem....Ran great...would back fire...lost power and slows down. I would take my foot off the gas and then would run fine for a while.
Old 12-21-2000, 08:16 PM
Phillip Guidry Phillip Guidry is offline
Phillip Guidry is starting off with a positive reputation.
Just A note on fuel filters for the 460 cab & chassis models, some models had 2 fuel filters per vehicle. One was the 3 line filter between the fuel pump and carb, and, some had a canister filter between the tank and fuel pump....check very closely for the "extra" filter. Also, the vacuum line tip is a good one....seen that one many times as well.
Phil
Old 12-22-2000, 06:13 PM
deleontow deleontow is offline
deleontow is starting off with a positive reputation.
I would check your fuel presure with a guage, you may have a fuel pump which can not keep up with the flow at higher rmps.
Dave
http://a2ztowing.homestead.com/a2ztowing.html
Old 12-28-2000, 04:09 AM
xaviar's Avatar
xaviar xaviar is offline
xaviar is gaining momentum as a positive member of FTE.
Yes Philip, you're right. Ford quit using that canister filter around 1992 or so because of the problems it was causing. No one knew about it to change it. I was told by a Ford dealer to remove the canister filter and just run the inline filter.
Xaviar
Old 12-31-2000, 10:02 PM
xaviar's Avatar
[font size="1" color="#FF0000"]LAST EDITED ON 31-Dec-00 AT 10:03 PM (EST)[/font][p]Hi Ken
Can you tell me if your truck is EFI or Carb? If it is EFI, do you have a MAP sensor or MAF sensor? I've been looking for a conversion kit for my truck to MAF. 96 F-250 460/E4OD. I've been told that a few Motorhome Chassis had MAF up till 1994 or so.
Have you ever heard of a MAF conversion kit for the 460?
thx
Xaviar
Old 01-06-2001, 08:35 AM
shami02 shami02 is offline
shami02 is starting off with a positive reputation.
You go Xavier, Keep looking for that MAF for our trucks... BTW you didn't answer my last post... Would you email me with the current results of you search I also have a few items to share...
Mike
1995 F-350 460 E4OD
Old 01-06-2001, 01:02 PM
xaviar's Avatar
>trucks...
I will not stop till it's found.......lol
>to share...
Just e'd ya this morning.
>Mike
>1995 F-350 460 E4OD
Old 01-07-2001, 02:30 AM
Thudpucker's Avatar
Thudpucker Thudpucker is offline
Thudpucker is gaining momentum as a positive member of FTE.
Dura-spark ignition module failure Brnfree 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 07-05-2015 02:36 AM
No power climbing hills ram0812 Ranger & B-Series 11 04-01-2012 07:42 PM
79 F100 breaks up at high RPM gixerbike1 1973 - 1979 F-100 & Larger F-Series Trucks 23 10-09-2010 05:19 PM
Do all 460 rear main seals leak! Paul Steele Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 12 01-21-2005 08:39 AM
87 F-250 Starter Solenoid fuzbuster 1987 - 1996 F150 & Larger F-Series Trucks 6 03-14-2003 11:44 AM
Tags
1979, 1995, 1996, 460, 95, bogs, f350, ford, ignition, issues, pack, peoblems, problem, problems, starting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
