do any of you guys no if 78 bronco balljoint is the same as the 78 250 4/4 balljoint for the top are the same why im asking is moog makes one with the grease fitting on the ege so you can grease it i keep gettyng the ones with the little plug in it and no way two grease it thanks any help would be nice
i might be wrong on this, but didnt the 250 come with a dana 60? the bronco and f150 came with the dana 44.. two completely differant nuckle assemblies. You can alwas drill a hole and add a zerk fitting to the joint, but be careful of shavings getting into the joint
butch250, the little cap that comes with the ball joint is used after you grease the ball joint with the zirk fitting, remove the zirk, install the cap and then you wont rip the grease fitting out with your axle when it rotates
