Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-05-2001, 11:01 AM
shami02 is starting off with a positive reputation.
Tensioner & Idler Pulley 95 f150
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-16-2001, 08:56 AM
mikedalton is starting off with a positive reputation.
Looking for advice on replacing the tensioner and idler pulley on a 95 F150 4x4 with 351.
The idler pulley should have right hand thread. Correct?
I recall an earlier post saying left hand thread but I want to know before I get in there and crank away. I've snapped a few
bolts in my time and donn't enjoy getting 'em out.
Is it a torx socket that is needed?
Any tricks on tensioner assembly or is that fairly straight forward?
I figure someone out there has done this and rather then waste my time pining over the Vikings I should get this project done.
  #3 (permalink)
Old 01-16-2001, 10:33 AM
PAUL_2 is starting off with a positive reputation.
Which part is the problem ? Its no big deal to replace the pulley if its making a noise . Remove the belt , remove the pulley . As far as I know the pullley bolt is not right hand thread . If the tensioner is defective then you will have little or no tension on the belt when installed , its basically just a big spring .
  #4 (permalink)
Old 01-16-2001, 10:40 AM
mag mag is offline
mag is starting off with a positive reputation.
I just did my 92. Not hard at all. The bolt came off real easy.
  #5 (permalink)
Old 01-16-2001, 10:42 AM
Originally thought it was only idler so I bought one to put on. Now it appears it is the bearings on the pulley on the tensioner itself. Does this come as a unit or just the pulley?
  #6 (permalink)
Old 01-17-2001, 12:06 AM
jakegypsum's Avatar
jakegypsum is starting off with a positive reputation.
Mike, You can get the entire unit from Ford. I have a 92' F-250 with a 351 v-8. The idler assembly cost me around $52.00. I believe that you can get just the pulley from a NAPA store for less $$$$. I am not positive if my idler would be the same as yours. Good luck.
Jakegypsum // Ford fleet, soup to nuts.
__________________
  #7 (permalink)
Old 01-17-2001, 12:15 AM
Ok, What leads you to beleive the belt tensioner or the pulley is the problem ? What is the problem you are experiencing ?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
