adjusting parking brake
Expedition's have a parking brake system similiar to that of a 1965 - '82 Corvette, i.e., a specially-shaped disc brake rotor that surrounds a small brake drum (which is the parking brake). According to my 1999 Ford Expedition Workshop Manual, the parking brake is NOT self-adjusting. In order to correct misadjusted brake shoes, the adjuster screw, located at the bottom of the shoes, has to be manually adjusted.
The Chilton's manual probably also contains info on the F-150 pickup, which was offered with rear drum service brakes that are self-adjusting.
I just did mine again, so here's the poop!
Parking brake adjustment instructions:
Turn off air suspension if you have it.
Block front wheels.
Make sure parking brake is released fully.
Crank engine, place tranny in 2wd mode, shift to neutral. Turn off engine.
Jack up vehicle until both wheels are off ground, support by jack stands.
Under vehicle remove 1" long rubber plug from bottom of brake backing plate under axle.
Insert short, flat blade screw driver to engage grooves in star wheel of adjuster.
Turn star wheel upward with screw driver tip until vehicle wheel will not rotate by hand even slightly.
Back off (turn star wheel down) five or six screw driver swings.
If Wheel soes not not rotate by hand, back off more, one swing at a time. When wheel moves. Replace rubber plug and do same on other side.
Check parking brake travel. It should be much improved.
Hope this helps.
Block front wheels.
Hope this helps.
Thanx to all for the insight. Found out what happened to the parking brake. Didn't have the time to do it myself, so I took it to a brake place( George Foreman's people), and came to find out that the whole assembly for the parking brake system was shattered and floating inside the rotor. Don't ask me how, but the guy said he has seen it before on the 97 Expe's. Had to put that assembly on first, couldnt put the rotor or wheel on until that was done. I still cant believe it.
PbFoot
So what you are saying is ford designed a parking brake system that needs to be adjusted by crawling underneath?
I don't buy it......mine had the same problem but it was just too far out of adjustment on one side..........once i adjusted it everything was cool and that was over a year ago and i use it everyday(park on steep driveway).......and haven't touched it since and pedal height is still way up at top................i would think there's gonna be wear after all there's friction involved and i put it in drive to make sure it's still holding since my light doesn't work(stoppped working at 36k) and don't want all the weight on the parking pin.............my slightly experienced un-educated guess is that it adjusts when you use it.........and IF you don't use it all the time don't use it at all
but i could be wrong
Dalejarretfan,
If a driver uses the brakes hard in reverse everyday, they should be self adjusting. I don't do that, so mine were never given enough torque to self adjust. This is common with most drivers so that is why there is a manual advance mechanism. Also, this method allows for releasing the tension for servicing the rear brakes, removing rotor, etc.
Hope this helps clarify.
the parking brake design with the shoes inside the rotor do not adjust by rolling back on it..they adjust by using it........backing up on your rear calipers is not going to do anyhting but waste lining......backing up on the parking brake isn't a good thing either it will shatter the shoe linings.....if they are adjusted at all......way out they won't adjust either
