adjusting parking brake - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 10-14-2003, 10:07 PM
drielle drielle is offline
drielle is starting off with a positive reputation.
I have a 97 Expedition, and I noticed that lately my parking brake won't stop it from rolling when I put it in neutral. I know on some Fords, the brake can be adjusted. How do I adjust the parking brake on my X-Pa?
Old 10-17-2003, 12:13 PM
joed_6 joed_6 is offline
joed_6 is starting off with a positive reputation.
same thing started on my wife's 97 expy. trying to find out also.
Old 10-17-2003, 09:01 PM
PbFoot PbFoot is offline
PbFoot is starting off with a positive reputation.
My Chiltons manual just says the brake is "self adjusting". That's a big help, huh?
PbFoot
Old 10-17-2003, 09:29 PM
PaulC PaulC is offline
PaulC is starting off with a positive reputation.
Expedition's have a parking brake system similiar to that of a 1965 - '82 Corvette, i.e., a specially-shaped disc brake rotor that surrounds a small brake drum (which is the parking brake). According to my 1999 Ford Expedition Workshop Manual, the parking brake is NOT self-adjusting. In order to correct misadjusted brake shoes, the adjuster screw, located at the bottom of the shoes, has to be manually adjusted.
The Chilton's manual probably also contains info on the F-150 pickup, which was offered with rear drum service brakes that are self-adjusting.
Old 10-18-2003, 12:01 AM
BigMattXXL's Avatar
BigMattXXL BigMattXXL is offline
BigMattXXL is starting off with a positive reputation.
Paul's right - it's not self adjusting. It's got a standard adjuster screw in there.
Is the problem relatively new? You might want to inspect the cable and make sure everything's in order.
XXL
Old 10-18-2003, 03:49 PM
tsdrallyer tsdrallyer is offline
tsdrallyer is starting off with a positive reputation.
I just did mine again, so here's the poop!
Parking brake adjustment instructions:
Turn off air suspension if you have it.
Block front wheels.
Make sure parking brake is released fully.
Crank engine, place tranny in 2wd mode, shift to neutral. Turn off engine.
Jack up vehicle until both wheels are off ground, support by jack stands.
Under vehicle remove 1" long rubber plug from bottom of brake backing plate under axle.
Insert short, flat blade screw driver to engage grooves in star wheel of adjuster.
Turn star wheel upward with screw driver tip until vehicle wheel will not rotate by hand even slightly.
Back off (turn star wheel down) five or six screw driver swings.
If Wheel soes not not rotate by hand, back off more, one swing at a time. When wheel moves. Replace rubber plug and do same on other side.
Check parking brake travel. It should be much improved.
Hope this helps.
Old 10-22-2003, 12:28 PM
Thanx to all for the insight. Found out what happened to the parking brake. Didn't have the time to do it myself, so I took it to a brake place( George Foreman's people), and came to find out that the whole assembly for the parking brake system was shattered and floating inside the rotor. Don't ask me how, but the guy said he has seen it before on the 97 Expe's. Had to put that assembly on first, couldnt put the rotor or wheel on until that was done. I still cant believe it.
Old 10-22-2003, 01:55 PM
I seem to recall a problem with Expy's that were accidently driven in Reverse while in 4Lo with the parking brake on. This would damage the parking brake system.
Old 10-22-2003, 02:04 PM
ineedashot's Avatar
ineedashot ineedashot is offline
ineedashot is starting off with a positive reputation.
Excellent Instructions tsdrallyer!
Thanks for sharing the knowledge...
Yanks, two down and two to go!
Old 10-22-2003, 04:22 PM
I second the motion!!!!
PbFoot
Old 10-22-2003, 04:43 PM
Quote:
You are right. Chiltons does have a section on the F-150 brakes. Apparently Chilton editors didn't do their homework. This is not the first time I have encountered an error in Chiltons. Thanks for giving us the straight scoop!!
PbFoot
Old 10-23-2003, 08:11 AM
dalejarrettfan dalejarrettfan is offline
dalejarrettfan is starting off with a positive reputation.
So what you are saying is ford designed a parking brake system that needs to be adjusted by crawling underneath?
I don't buy it......mine had the same problem but it was just too far out of adjustment on one side..........once i adjusted it everything was cool and that was over a year ago and i use it everyday(park on steep driveway).......and haven't touched it since and pedal height is still way up at top................i would think there's gonna be wear after all there's friction involved and i put it in drive to make sure it's still holding since my light doesn't work(stoppped working at 36k) and don't want all the weight on the parking pin.............my slightly experienced un-educated guess is that it adjusts when you use it.........and IF you don't use it all the time don't use it at all
but i could be wrong
Old 10-23-2003, 10:16 AM
Dalejarretfan,
If a driver uses the brakes hard in reverse everyday, they should be self adjusting. I don't do that, so mine were never given enough torque to self adjust. This is common with most drivers so that is why there is a manual advance mechanism. Also, this method allows for releasing the tension for servicing the rear brakes, removing rotor, etc.
Hope this helps clarify.
Old 10-23-2003, 11:19 AM
the parking brake design with the shoes inside the rotor do not adjust by rolling back on it..they adjust by using it........backing up on your rear calipers is not going to do anyhting but waste lining......backing up on the parking brake isn't a good thing either it will shatter the shoe linings.....if they are adjusted at all......way out they won't adjust either
Old 10-23-2003, 11:42 AM
Very true. Think about it. The primary use of the parking brake is to hold the brake drum in place AFTER the vehicle has come to a complete stop. Under those circumstances, how would the star adjusting mechanism commonly used on drum service brakes ever come into play?
How do I adjust the parking brake? bill11012 1999 to 2016 Super Duty 25 01-15-2016 06:02 PM
1949 F1 parking brake rbr658 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 07-15-2015 12:34 PM
lost parking brake after brake job sudsmcduff 1999 - 2003 7.3L Power Stroke Diesel 20 05-25-2015 02:51 PM
Parking Brake kent521 1994.5 - 1997 7.3L Power Stroke Diesel 1 04-12-2011 12:12 PM
1965 f-100 how to adjust parking brake? neumannfamily 1961 - 1966 F-100 & Larger F-Series Trucks 11 04-12-2009 11:11 PM
Tags
08, 150, 2004, 46, adjust, brake, brakes, emergency, escape, f150, ford, fords, operation, parking, rear
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
