Code P1131 and P1151 - Ford Truck Enthusiasts Forums
Old 10-14-2003, 08:08 PM
aggiepapa72 aggiepapa72 is offline
aggiepapa72 is starting off with a positive reputation.
Lightbulb Code P1131 and P1151
My '98 Navigator has displayed codes P1131 and P1151 on my scanner and say "Manfacter Contrls. fuel air meter". What does this mean? The spelling in the " " is how it actually reads.
Old 10-14-2003, 11:48 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
It mayjust be extremely dirty. I would spray the small wires in the meter (located in the engine side of the air cleaner housing) with carb cleaner (engine off). Also check the wires to make sure that they are ok.
And I just wanted to say Welcome To FTE. I think that you will find a whole lot of useful info here.
Jimmy
Old 10-16-2003, 02:07 AM
wmcnally wmcnally is offline
wmcnally is starting off with a positive reputation.
pappa,
These codes indicate a LEAN condition in banks 1&2.
1) Clean your MAF and than disconnect your battery to reset your PCM. If the code(s) come back...
2) Do a search on the word "Lean". The posts will tell you to check for vacuum leaks. (unmetered air getting into your motor will cause a lean condition.)
If you need more help, don't hesitate to post again.
Good Luck,
Bill
Old 10-16-2003, 09:56 PM
Thumbs up
I found the problem. Thanks for the help. It was a deteriorated boot on the vacuum end of the PCV line where it connects on the back end of the throttle body.
Old 10-17-2003, 12:02 AM
LxMan1's Avatar
Glad to hear you got it fixed
This seems pretty common, they must be using cheap rubber products these days.
Jimmy
Old 10-18-2003, 02:21 AM
re-engineered re-engineered is offline
re-engineered is starting off with a positive reputation.
The codes that you are speaking of concern the Ho2 sensors that are right after the exhaust manifolds. Usually accompanied by o2 sensor slow to read codes means its time to replace the heated o2 sensor.
Old 05-24-2010, 08:16 PM
marks500's Avatar
marks500 marks500 is offline
marks500 is starting off with a positive reputation.
Same Problem... Help?
Didnt want to start a new post on this.. I just had My Check engine like checked and I had the same Codes showing P1131 and P1151. The Idles Rough but runs Fine, Gas Mileage seems to be worse... Where do I start? It seems like it could be a few things... Dont want to just throw Parts at it. Any help I would Appreciate! Thanks, Mark
Truck Info: 1997 Ford F-150 5.4L
1998 F250 P0171 f250jpk 1999 to 2016 Super Duty 0 07-31-2012 05:24 PM
4.2 surges& runs rough till warm cabledog77 3.8 & 4.2L V6 2 04-14-2010 03:04 PM
Codes: P0401, P1151, P1131 Help! Wolf1200 1997 - 2003 F150 3 05-06-2009 02:28 AM
p1131 and 1151 FordTrucks4Life 1997 - 2003 F150 7 02-20-2008 04:53 PM
03 Expedition P1151, P1131 t0mkat Expedition & Navigator 3 06-24-2007 06:35 PM
Tags
1997, 1999, 2002, code, codes, codigos, dx, expedition, f150, ford, mustang, navigator, o2, p1131, p1131p1151, p1151, sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
