93 Aerostar Transmission
Hello all,
I have owned an 89 Aerostar for 4 years and the transmission has had the overdrive "hunting" problem for the last year. I test drove a 93 Aerostar with 190,000 KM and it was very noticeable with the shifting as quite hard. The overdrive worked ok but compared to my 89 that you hardly notice the shifts I am wondering if the hard shifts are normal for 1 to 2 to 3? Was my transmission just weak and that is why it shifts soft? Do the hard shifts indicate a different problem? Just wondering if I should but this van or not.
Thanks, Brian.
Thanks, Brian.
Find out if the transmission has been replaced on the '93. If it has or it has been worked on, the modulator may be incorrectly adjusted or an incorrect one has been used. The shifts should be smooth and responsive, even with high mileage.
The problem you describe has been mentioned frequently on this forum. The pattern generally goes as follows: previous owner suspects transmission problem and takes van in for work. The transmission winds up eitherrebuilt or replaced. After spending big bucks, the transmission shifts worse than before. Owner gets fed up and trades in the van rather than spend additional dollars.
Modulator problems are easily remedied if this is the case.
It seems that the transmission was not worked on but I am not sure. I could change the modulator easily but how would I know if the wrong one was on now? Also I did not know it was adjustable. How do you adjust it? I did replace the one on my 89 Aerostar years back but I remember only installing it without any kind of adjustment.
Thanks, Brian.
Thanks, Brian.
Here's some reading you might find interesting.
https://www.ford-trucks.com/forums/s...5252Bmodulator
After driving the van more and playing with the modulators I believe it is not my problem. The transmission does not want to shift from 1st to 2nd when cold (below 0 C) at all but if I manually shift to 2nd it works. After it will shift on its own and when warm seems to shift very well to all gears. Does this sound like the valve body? Has anyone else had this problem and know the fix?
My fluid level is correct and it looks red and no smell, but I am not sure if the previous owner did a service shortly before he sold it.
Thanks, Brian.
Thanks, Brian.
I decided to add a small bottle of transmission additive that described "smother shifts" and "coats internal parts" and after about 150 km it no longer does the cold delayed 1st to 2nd shift. It has worked every morning for over 1 week now and it has been quite cold for some of the days. I bought the additive at Wal Mart but can't remember the name. The next time I go back I will make a note of it and post it. I guess my issue was something sticking and it was helped by this additive. Thanks again for the posts.
Brian.
Brian.
Well, its funny. I had the problem gone for awhile and then it was back for a few weeks. Then it went away again and the shifts are happening ok in the morning without the long delay to shift into 2nd. It still has more "hard" shifts that my 89 Aerostar ever had but it seems to be ok and the overdrive works very well and that alone is GREAT as my 89 kept shifting out and in of overdrive all the time.
Brian.
Brian.
Thanks for the updates, it is always nice to know how these problems play out, successful or not. Wish more people would follow up like you have.
As to your persistent problem with hard shifts, I reviewed your earlier posts and one question comes to mind. Have you verified an accurate transmission fluid level? The A4LD is very sensitive to improper levels. It could be the additive volume was enough to bring the fluid level into range thus making the transmission work properly. Then too, you could have sticking valve(s) that are being helped by the additive. Might not hurt to repeat the additive one more time, drive it a week and then drain and replace with just transmission fluid.
i have a 93 ford aerostar and it shifts into gear very smoothly i would have it check by machanic first before you bought it. you cant even tell when it shifts it is so smooth check the fluid level a low level can cause it to feel ruff when you shift - which leads to the question is it leaking fluid and why.
brianwetzel does it seem like the transmission shifts at a good rpm or does it shift early or late. There is a possiblity that you have a problem with the kickdown cable. I don't know that it is you problem but a messed up cable adjustment can mess up your shifting. It looks like on my 93 areo the cable adjustment is behind the gas pedal. The tighter the cable the later it will shift. The shift is also harder.
