Power Steering Pressure Switch - Ford Truck Enthusiasts Forums
Old 02-26-2001, 12:11 AM
twerba twerba is offline
twerba is starting off with a positive reputation.
I was recently working on my 1992 Ford Bronco and found a wire that was burnt from touching the exhaust manifold. I think it goes to a Power Steering Pressure Switch.? I looked it up in a Hanes Manual. The wires are Yellow/Light Green - and - Grey/Red. The grey/red wire supposedly is connected to the EGR valve, air temp. sensor, and the throttle position sensor. Can anyone tell me where I can find this Power Steering Pressure Switch under the hood. I have looked and cannot find. Could this cause the truck to stall when coming to a stop? Any help would be appreciated. Thank you.
Old 02-26-2001, 03:06 AM
hotrodford_88 hotrodford_88 is offline
hotrodford_88 is starting off with a positive reputation.
Your power steering pressure switch is mounted in the pressure line going to the steering gear box. Just follow your power steering lines from the pump and you will run right into it. It is screwed into the line, and is only (I think) available from Ford. Or a wrecking yard, which is where I grabbed mine at, when I did the engine swap.
1988 F-150, SWB, 5.0 EFI (formerly 4.9 EFI), M5OD 5 speed, 3.08 gears, Summit shorty truck headers, Custom built Flowmaster exhaust system. Force 4 LP6000 lightbar, Federal signal PA-300 100 watt siren, Icom IC-V100 50 watt mobile radio.
1965 F-100 (just purchased 1/18/01), SWB, 390, C-6 auto. Dual exhaust, Not much else to do to it.
Can see both below.
[link:www.geocities.com/hotrodford_88/|Hotrodford_88's Webpage]
Old 02-26-2001, 04:51 PM
Thanks for the help. I like the truck, looks great. Where are you a volunteer form ? - I'm a Lt. in New York.
Old 02-27-2001, 06:41 AM
I work with a Volunteer dept in SE Texas. Right now we have around 45 members, and have an area of 51+ Square miles. We have a website that I have been trying to work on in my spare time (when I have some that is.)
[link:www.westlakevfd.org|Westlake VFD]
Let me know what you think, I haven't had much time to work on the site (either one) but not all of our equipment is up on the site yet. We have currently 2 stations, with 2 engines and 1 tanker at our secondary station (750 gpm, and a 1,000 gpm pumper, and a 1500 gallon tanker) and our primary station holds our 2,000 gal tanker, our primary engine (1,000 gal capacity, and 1,000 gpm pump) our secondary engine (750 gal capacity, and 750 gpm pump) our rescue truck (750 with 750 pump) and 1 (of three) ambluances.
And get this, all of our equipment except one engine (at our secondary station) is ALL FORD! Our trucks range in age from 1964 - 1979 Engines, tankers, and rescue truck. Our ambulances are all Ford as well, 1985 - 1993. The one engine that is not a FOrd is an International Diesel. Which I don't mind but I've never personally even been behind the wheel of it. But I have been behind the wheel of about every other piece of apparatus we have, save for the big tanker. I am a Lieut. on the rescue truck and have only been in our dept for a little over a year.
Can see both below.
Old 02-27-2001, 09:36 AM
biohazard biohazard is offline
biohazard is starting off with a positive reputation.
Power Steering pressure Switch Location hreyesg 1987 - 1996 F150 & Larger F-Series Trucks 7 10-19-2013 02:19 AM
upfitter wiring os250 6.0L Power Stroke Diesel 11 08-08-2012 01:54 PM
08 Memory Seat diagram? N4TECguy 1999 to 2016 Super Duty 3 09-04-2011 11:36 PM
power window help and other electrical issues joelswork 1968-2013 Full Size Vans 1 09-13-2010 07:09 PM
Wiper/Washer wont work TruckNut Ranger & B-Series 5 09-10-2003 04:31 PM
Tags
1987, 2003, electrical, escape, expedition, f150, f250, ford, power, powersteering, pressure, pump, steering, sterring, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
