Firewall Busted around clutch master
Old 02-28-2001, 08:29 PM
cledust's Avatar
cledust
cledust is offline
I have an 88 F350 CC, w/ 7.3 L Diesel. The fire wall is busted around the master cylinder. Is there any way i can fix this cheap or somewhere i can buy a new one?
Old 02-28-2001, 09:52 PM
jakegypsum's Avatar
jakegypsum
jakegypsum is offline
I am not sure if ford has an available plate for the master cylinder. Many people have posted problems like this. Many have fabricated a plate or at least washers where the master bolts up to the fire wall. A lot of people have noticed problems with clutch actions without getting to the point of the fire wall being busted out. It may be a make/shift type of thing good luck.
Jakegypsum // Ford fleet, soup to nuts.
Old 02-28-2001, 10:14 PM
bjoern's Avatar
bjoern
bjoern is offline
Clutch master cylinder - firewall reinforcement kit:
Ford part number: E8TZ7K509A
1988 F-150, 5.0L 302ci, 5spd, SuperCab. Shorty headers, K&N filter, Accell 300 8.8mm race wires, Accell supercoil, Accell rotor+cap, Bosch +4 Platinum plugs, RanchHand bumper. Soon: MSD 6a ignition and dual exhaust.
Old 02-28-2001, 11:47 PM
jakegypsum's Avatar
jakegypsum
That's right! I forgot about that kit. I never had to use one but I now do recall that Ford did come up with one.
Old 03-01-2001, 09:52 PM
Mulletwagon's Avatar
Mulletwagon
Mulletwagon is offline
>kit:
>exhaust.
Got the same problem on an 88 Bronco. Went down to the old Ford dealer today and asked about the reinforcement panel. The small one is not very effective and cost $4. The big heavy duty one that is used on the F-350s is $100 - ouch !!!
Old 03-02-2001, 06:21 PM
billjackson's Avatar
billjackson
billjackson is offline
I had this problem with the F250. The cause was an exhausted pressure plate that needed replacement. The fingers were heat stressed to the point that it required extreme pressure to disengage the clutch. I removed the master cylinder and mig-welded a plate over the area. Of course after replacing the clutch assembly.. Good luck..
Old 03-02-2001, 09:34 PM
carlos57's Avatar
carlos57
carlos57 is offline
Bigsandy
09-25-2016 01:46 PM
Rufus1945
New Member Introductions
05-04-2016 03:23 PM
DerekShiekhi
Paint & Bodywork
12-04-2015 05:51 PM
zenish
Aerostar
07-15-2015 08:28 PM
busted 55
08-05-2014 01:23 AM
Quick Reply: Firewall Busted around clutch master
