trailer light problems - Ford Truck Enthusiasts Forums
Old 10-13-2003, 03:19 PM
bluemoose89 bluemoose89 is offline
bluemoose89 is starting off with a positive reputation.
i am having trouble wityh the trailer lights on my 99 psd i have hooked up to 2 diffrent trailers sometimes they dont work at all and other times the blinkers dont work nor the brake lights but the running lights work...and suggestions?
Old 12-23-2003, 05:03 PM
'98 Ford F150 '98 Ford F150 is offline
'98 Ford F150 is starting off with a positive reputation.
I am having the same problem. The lights on the truck work fine. I tested the plug and am not getting anything there. Have you corrected your problem yet?
Old 12-23-2003, 06:43 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Are those trailer plugs Matched to the *Standard Positions* per the connector?
http://mil1ion.clubfte.com/Trailerwiring.jpg
I have my trailer connector set special for me & MY truck.
I also have pigtails that converts it to standard wiring.
If someone tries to steal it ,they will noticed by other drivers.
The other thing is I have the continuous power to trailer actually hooked up to the trailer brakes.
Old 12-23-2003, 07:29 PM
Mil1ion,
Mine look exactly like the photo, (factory install). The trailer lights have worked for years. I hooked up yesterday and had nothing but taillights!! I have tested the harness on the truck and it seems o.k. (continuity check). I hooked the trailer to another vehicle and it works perfectly.
Thanks,
Ken
Old 12-23-2003, 08:56 PM
Possible corrosion at the Truck connection terminals ?
Old 12-24-2003, 09:32 AM
I disconnected the harness and checked the terminals. They were in great shape.
In searching previous posts, I notice that this is not that uncommon an occurrence. The posts that I have reviewed however do not give explanations as to how the problem was solved. I cannot directly e-mail anyone because I have not been a member long enough and do not have enough posts. Frustrating!!
Thanks,
Ken
Old 12-24-2003, 11:29 PM
WhipsnHorses directed me to a third fuse box that was not mentioned in my owners manual. 20 amp mini fuse blown. Trailer lights operational once again. Thanks so much for the help.
Ken
Old 12-25-2003, 04:12 AM
Yes frustrating it is when people don't follow up thread with the end result being positive or negative.
Mostly it is because people don't go ( too lazy) find that original thread to update.
Glad you got it fixed
Old 12-25-2003, 09:07 AM
Thanks for the note Dennis. I guess the third fuse box wasn't detailed in the owners manual because the towing package was an option(???). Anyway,... lesson learned...
Merry Christmas,
Ken
Trailer running & tail lights don't work. silentrunning 1987 - 1996 F150 & Larger F-Series Trucks 9 02-24-2012 07:20 AM
Trailer lights not working lakewood 1999 to 2016 Super Duty 7 04-27-2011 12:06 AM
No running lights on trailer Deerslayinrenek 1987 - 1996 F150 & Larger F-Series Trucks 3 06-25-2010 04:58 PM
No brake lights to the trailer. Which fuse is it? Thudpucker Electrical Systems/Wiring 7 09-29-2006 03:53 PM
Trailer Wiring Problem - no trailer running lights jjbigwheel Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 4 09-28-2006 09:16 PM
Tags
2004, 2007, f150, ford, issues, light, lights, problems, trailer, troubleshooting, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
