Rear Differential Vent Tube - Ford Truck Enthusiasts Forums
Old 10-13-2003, 02:02 PM
cje07's Avatar
cje07 cje07 is offline
cje07 is starting off with a positive reputation.
I have an 86 ford bronco with a 9" rear end. Question: What would cause the vent tube to leak gear lube? I just recently replaced the pinion seal hoping for no more leaks...that was 7 days ago. Went in the garage and now it looks like the vent tube was leaking on the floor. Any ideas? Was it pushing out excess fluid? Help!!
Old 10-13-2003, 02:04 PM
dbc dbc is offline
dbc is starting off with a positive reputation.
Most likely it is overfilled
Old 10-13-2003, 02:31 PM
rebocardo rebocardo is offline
rebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud of
Sounds like it was overfilled. You should have a hose on the vent tube, if not, it is possible for it to suck water during a heavy rain or big puddle.
The other thing to check is to make sure you do not have a brake line leak since the brake line banjo goes around the vent on some Ford axles (like my 1971 F-100).
Old 10-13-2003, 02:37 PM
cje07's Avatar
Vent Tube
Yes the tube is there and clipped in the vertical fashion. I did check it out and the leak is coming from the top of the vent tube and follows the hose down to its lowest point, where as distrubuting the gear lube on the garage floor...I'm thinking at this point it is just overfilled. If anyone thinks otherwise please let me know. Thanks guys!
Old 10-13-2003, 02:40 PM
Mike W's Avatar
Mike W Mike W is offline
Mike W is starting off with a positive reputation.
You can also extend it.
Old 10-13-2003, 02:42 PM
cje07's Avatar
Vent Tube
Excellent idea...do think a garden hose will work....just kidding!!!
Old 10-13-2003, 03:37 PM
KJKozak2 KJKozak2 is offline
KJKozak2 is gaining momentum as a positive member of FTE.KJKozak2 is gaining momentum as a positive member of FTE.
Overfilling would be my guess too. Either that or driving it on a 45 deg. angle.
If you do any offroading, extending it is a great idea as Mike W suggested. I had mine 38" above the ground and still sucked water into the dif..
Now, all my vent tubes for the axles and t-case are run through the firewall and up under the dash in the cab.
Kevin K.
Dana rear end vent tube leak JoeJJones 1987 - 1996 F150 & Larger F-Series Trucks 2 08-27-2014 10:27 PM
Breather vent on a Ford 10.25" Differential? MontanaMan 1987 - 1996 F150 & Larger F-Series Trucks 2 07-04-2014 08:32 AM
1994 7.3l idi fluid coming out of vent tube between trans and engine kjjr20 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 02-24-2014 09:21 AM
transfer case vent tube leak? dangrimsley 1997 - 2003 F150 2 11-08-2003 09:25 PM
Axle vent valve? Boss300 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 03-15-2002 05:45 PM
Tags
150, 1967, brake, differential, duty, f150, ford, gearlube, hose, inch, rear, super, tube, vent, vents
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
