I have a 1975 ford f150 I need front sway bar mounting bracket I have sway bar already. Ichecked dealer and they could not get one, were would I get them.
What you actually need is the copmplete spring perch, not just a bracket. I had to get mine from a junkyard. You also need the brackets that mount the center of the bar to the chassis and the end links if you didn't get them with the bar
