my 460 has a regular and slight surge at idle. does not seem to matter how i adjust the injectors it does not go away. does this sound like an intake or base of the throttle body leak. any other suggestions?
I would say it is the IAC, but I don't think that your set-up has one.
Does this set-up use an EGR valve? Could it be slightly stuck open?
It could be a vacuum leak and the O2 sensor is contantly correcting the mixture causing it to hunt for the proper set up all of the time.
Jimmy
