1984 F 150 duraspark conversion
I currently have TIF IV ignition on my 84 F150 4.9L 6. I have replaced it twice once at 75,000, once at 150,000 and i now have 200,000 on the truck. I think there is a trend forming here and i am thinking about converting to a duraspark ignition before it leaves me again.
I have studied all the shop manuals and electrical schematics, and it looks like I will have to change the distributer, carborator, and will need the duraspark harness.
The electrical schematic for the 84 4.9 shows both ignition systems and the wiring looks easy. However, there is a question about wether the balast resistor is allready in the harness or if i will have to install one.
How could i check this. ?
Sail, you won't have a ballast wire/resistor with the TFI ignition (and the E type coil). As Mike says, use an external one with the DuraSpark.
In my opinion however, it's not worth the swap. I would just change the TFI module every 75K as regular maintence. Or better yet, find a way to keep it cooler or change it's location.
The Duraspark modules also go bad on a fairly regular basis. I always carry a spare in my center console.......
on
Some good info here....
https://www.ford-trucks.com/2_8Duraspark.html
Although it is for a conversion of a 2.8Litre engine in a BroncoII/Ranger the principles are the same.
maf226
05-03-2017 10:51 AM
MrFord619
01-26-2017 07:06 AM
49fordv8f4
07-09-2016 06:02 PM
84chateau
05-18-2016 09:52 AM
Mgbarre
05-05-2016 09:30 AM
