F-150 302 engine diagram - Ford Truck Enthusiasts Forums
Old 10-08-2003, 03:13 PM
jhc111 jhc111 is offline
jhc111 is starting off with a positive reputation.
Does anyone out there have an engine diagram for an '87 F-150 302? Mine has a few loose hoses that I can't locate the other end of.
Old 10-08-2003, 04:45 PM
Burris1974 Burris1974 is offline
Burris1974 is starting off with a positive reputation.
If they are vac. hoses there is (should be) diagram on the airbox lid.
Old 10-08-2003, 06:20 PM
These hoses have one outlet to the right valve cover and one behind the engine that I can't see, but both are broken off. I also want to know what the "coffee can" is for.
Old 10-08-2003, 06:21 PM
Old 10-08-2003, 10:09 PM
danpiscotty danpiscotty is offline
danpiscotty is starting off with a positive reputation.
Coffee Can
The coffee can is a vacuum reservoir. It's there to keep a constant amount of vacuum for your engine. If you do not have a diagram on the inside of your hood or right in front of the radiator then you'll need a book. YOu really should have one. They're about 20 bucks at the auto parts store.
Old 10-08-2003, 11:03 PM
I have the full shop manual but it negates mentioning many of the side items on my engine. Does anyone know where the other end of the hose to the right valve cover goes? It splits in a Y at that point and continues down stream.
302 Vacuum Hose Diagram?? JoeTaco1 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 09-02-2010 09:36 PM
need vacuum hose diagram 1988 F150 302 kodyowenby10 1987 - 1996 F150 & Larger F-Series Trucks 3 04-25-2007 09:05 PM
'94' F150 wiring diagram? ILovePkr 1987 - 1996 F150 & Larger F-Series Trucks 3 03-29-2004 10:56 PM
82 f-150 fuse panel diagram LabmanOK 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 0 03-05-2004 02:25 PM
1979 ford f150 302 engine vacuum hose diagram snow991025 1973 - 1979 F-100 & Larger F-Series Trucks 7 10-09-2002 10:06 PM
Tags
150, 1994, 1996, 1997, 302, 87, diagram, engine, f150, ford, layout, schematics
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
