Coolant temp Sensor - Ford Truck Enthusiasts Forums
Coolant temp Sensor
Old 10-08-2003, 09:09 AM
Smokey0210 Smokey0210 is offline
Smokey0210 is starting off with a positive reputation.
Coolant temp Sensor
I have a 1988 F-150 with a temp gauge that doesn't function. I replaced one temp sensor on the heater core line by the water pump but the gauge still is not moving. Is there a second sensor for the gauge? Somebody please let me know.
Old 10-08-2003, 09:51 AM
95se5m's Avatar
95se5m 95se5m is offline
95se5m is starting off with a positive reputation.
There is another sensor on the rear passenger side of the block directly beneath the Lower Intake Manafold.
Temp Sensor Location
This pic should help.
Old 10-08-2003, 12:36 PM
thanks
thanks for that pic it helps a lot. I suppose that I need to drain the coolant for that to work properly? No big deal if I have to I just hate refilling cooling systems.
Old 10-08-2003, 04:17 PM
95se5m's Avatar
To be honest, I am not sure. I would assume it's in the water jacket, and will spill out if you remove the sensor. I would drain it and fill with new anyway, it's a cheap maintenance item in my opinion.
Old 10-09-2003, 08:05 AM
FUEL TANKS
THANKS FOR THE HELP I AM GOING TO SWITCH IT THIS WEEKEND. ALSO DO YOU KNOW BY CHANCE IF EACH FUEL TANK RUNS OF SEPERATE SENORS BECUASE MY FRONT TANK HAS A LEAK AND MY REAR GAUGE IS EITHER FULL OF EMPTY THERE IS ABOUT TWO SECOND OF BOBBING IN BETWEEN E AND F BEFORE IT LETS YOU KNOW "OH BY THE WAY YOUR OUT OF GAS"
JUST AN AFTER THOUGHT THANKS.
Old 10-09-2003, 08:28 AM
95se5m's Avatar
Each tank has it's own sending unit that feeds through the switch on the dash. I did alot of research into this because I designed a circuit that has a red/green led next to each end if the switch, if the tank is below 15% it shows red. I wanted something to remind me when the tank I am not using is empty so I remember to fill it before I need it.
But short answer, 2 sending units, check the contacts and the switch first however, it's the cheeper option if all it is, is a loose wire(s).
Old 10-09-2003, 09:48 PM
skidj0003 skidj0003 is offline
skidj0003 is starting off with a positive reputation.
The temp sender on the side of the block will leak antifreeze when removed. It is difficult to get at. I was told to be careful when installing the new one so that the threads made good contact with the block.
Old 10-10-2003, 09:03 AM
By good contact do you mean for a ground or don't strip the threads? I was looking for the sensor yesterday and I have no clue how I will have to contort my self under the hood to get at that thing. Thank you Ford for a great position.
Old 10-10-2003, 10:53 AM
rhetor rhetor is offline
rhetor is starting off with a positive reputation.
I got under my truck and removed mine. Its a 4x4 also so the space was a bit tough, but it worked.
To be honest i forgot how i got the dang thing off, but it wasn't too difficult...
The coolant sensor is in a water jacket, it'll start pooring out when you take it off. I just sort of swapped fast and put some more coolant in there. Not such a great idea though... thats just asking for an air pocket
The one you replaced is for the ECM temperature sensor, so its not gunna help your gauge..
Old 10-10-2003, 01:02 PM
Thanks for the advice I plan on doing it tomorrow so I will post how it went.
Thanks again
Old 10-10-2003, 05:42 PM
Thread contact for an electrical ground is my assumption. I recall testing it with an ohmn meter.
Old 10-10-2003, 05:45 PM
I used a very long extension with a universal joint and ratchet. I think that I also disconnected the battery ground as it required working close to the starter connections.
Old 10-13-2003, 08:31 AM
Turned out to be fairly easy. I just laid down on the motor with my feet on the driverside and reached down with a wrench. I ended up not getting a bubble or a crossthread. Lost maybe a cup of coolant then just added in the resivior. The truck runs at the "O" in NORMAL. I also found that the line that goes from behind my first cat had the smog pump line disconnected (that would explain the headaches I was getting) so I reconnected that. Now the only other thing I have to do is fix the leak in th front tank and the sending units. The rest that is wrong with the truck is rust and there is no curing that on this one. But it runs strong. Thanks for the advice
Jordan
Oil/Trans Temp "combo" gauge?? finallyo3gt 1994.5 - 1997 7.3L Power Stroke Diesel 18 07-16-2016 09:47 PM
Temp guage Whynotgman 1978 - 1996 Big Bronco 3 06-16-2016 06:04 PM
temp gauge stainlessstroker95 1994.5 - 1997 7.3L Power Stroke Diesel 5 06-17-2011 09:18 AM
94 bronco temp sensor bh70116 1978 - 1996 Big Bronco 3 08-29-2010 07:32 PM
'04 E350 Coolant Temp Sensor Location? carrfamilynj 1968-2013 Full Size Vans 0 09-23-2006 10:54 AM
Tags
1989, 49, 49l, coolant, f150, ford, gauge, liter, location, oil, raptor, sender, sensor, temp, temperature
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
