Busted shifter!
Busted shifter!
1983 F-150
300 I-6 engine
"SROD" 4-speed overdrive transmission
The shifter has broken off! Yeah, the shaft that comes up out of the transmission. It's gotta be 1/2 diameter, and it just sheared off. There's about a 2.5" stub of the shaft sticking out above the plate.
The SROD tranny is the one with the shifter coming directly out of the top of the extension housing
I contacted a local dealer, and it turns out the part is discontinued. The guy at the parts counter suggested I get an aftermarket shifter kit. But later I realized this probably isn't possible; it looks like most aftermarket shifters (Hurst, etc.) only work on trannies with external linkages.
Options I'm exploring:
* Boneyard - hope that they'll sell me the shifter assembly, and not make me buy a whole darn transmission. We have few local yards, and nobody has one. I'll be in Detroit soon, but nobody around there seems to have one.
* Poss. aftermarket - maybe this is a common enough problem that there's an aftermarket shifter that interfaces directly with this tranny. So far I haven't found anything via Hurst or B&M.
* Repair - maybe somebody can weld the two pieces together, or since it broke within a sort of "collar" on the lever, maybe it can be adapted to attach to the stub that's left. Actually, a construction guy we met is gonna take a whack at welding it, but I've been told this probably won't last.
I've created a little web page with some photos to better describe what happened (it's kinda hard to describe it in text). So if you're morbidly curious, check out http://userpages.chorus.net/ptoleary/shifter .
Ideas? Help!
TIA,
Paul
300 I-6 engine
Ideas? Help!
TIA,
Paul
