Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel Sponsored By:
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 10-08-2003, 10:22 AM
dinebito is starting off with a positive reputation.
uh oh!! the 6.0L PSD is "Fly-by-wire"??? i did not know that... i learn many new things from this site everyday!!
__________________
Current: MY08 Hybrid Escape 4x4
Formers: MY03 F250 SD XLT CrewCab SB, FX4, 6.0L turbodiesel, 3.73 LS *** MY 07 F150 4x4 SCab, 5.4l. *** MY05 Hybrid Escape 4x4 *** MY03 Explorer V8 4x4
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 10-08-2003, 12:36 PM
jschira is starting off with a positive reputation.
ALL PSD's are fly-by-wire.
__________________
'08 Ranger
70 Bronco U14 Pickup
  #18 (permalink)
Old 10-08-2003, 12:56 PM
resqdawg3's Avatar
resqdawg3 is starting off with a positive reputation.
I didn't know that they were fly-by-wire until today when I finally decided to look under the dash board. I was trying to route out a spot for some speaker wires....Cool. I guess. lol
__________________
2003 F-250 6.0L Lariat, FX4. ZooDad Mod, 4" Turbo back exhaust, Diablo Predator, and another little tuner juuuuuuuust for me!
I don't mind being the "God of Death" forever....
  #19 (permalink)
Old 10-08-2003, 05:35 PM
bass1968 is starting off with a positive reputation.
I have had the same problem as DWolf and DucatiSSsp (nice bikes). It has only happened a few times, but just like you guys say it is when you put into rev. and then into drive. I do not have the adjustable pedels.
  #20 (permalink)
Old 10-08-2003, 08:17 PM
IB_Tim's Avatar
Administrator
IB_Tim has a spectacular reputation.IB_Tim has a spectacular reputation.IB_Tim has a spectacular reputation.IB_Tim has a spectacular reputation.IB_Tim has a spectacular reputation.IB_Tim has a spectacular reputation.IB_Tim has a spectacular reputation.IB_Tim has a spectacular reputation.IB_Tim has a spectacular reputation.IB_Tim has a spectacular reputation.IB_Tim has a spectacular reputation.
This going backward thing……….and then into drive, is the truck still rolling at all when you apply throttle to it, and it hesitates.
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
  #21 (permalink)
Old 10-08-2003, 10:05 PM
DucatiSSsp is starting off with a positive reputation.
Tim,
I would say that there is still some momentum when you drop it into gear and stab the throttle...but not much. Can't ever recall any of my vehicles with this much lag in the response of the throttle.
Cheers,
Bryce
BTW,
I am taking my truck into the Ford dealership to get the latest flash. The service writer said they would have to test my truck to see if it qualified for it. She somewhat questioned my ability when I told her I changed the oil and then the romping, smoke and erratic idle started. She thought I had been reading too many PSD forums and imagining this stuff. I let y'all know how it runs tomorrow evening.
__________________
2003 F250 6.0 PSD Lariat FX4 4X4 Sprcab longbed....a little overkill for hauling a dirtbike or two, but I always wanted a BPMDT(Big Pimp'n Mac-Daddy Truck)
Engine build date: 04/03/03
0058462-Huntsville, AL
  #22 (permalink)
Old 10-09-2003, 06:11 AM
IB_Tim's Avatar
Administrator
DucatiSSsp,
The reason I asked is the computer in these systems obviously has a feed back loop, hence the control process, there is a good possibility that if it is sensing a reward motion from a wheel sensor……. it might have a parameter within it that says “I can’t give it gas until it stops reward motion”
Now this never used to occur with mechanical throttles, fly by wire has a very different set of parameter before it will execute a command……………………….give it gas when applying throttle! If we knew the code then the max/min value could be changed. The difficulty here is “us” not being able to understand the methodology in writhing the code. This set point in the computer could be as little as a tenth of MPH. I understand why Ford would not want a big heavy monster with a bunch of HP to be capable of rolling backwards….. stomping on the throttle, and having interesting outcome. Of course the is all IMO.
__________________
Administrator
  #23 (permalink)
Old 10-09-2003, 06:24 PM
Quote:
Originally posted by Tim Lamkin
DucatiSSsp,
I thought the same thing, but you say it with much more mechanical ability or knowledge, guess why that's why I'm stuck workin in a grocery store Knew I shoulda listened to Mama and done did my homework!
I posted the following in "September 29 Flash" thread
Hi Guys,
Just got flashed!!.......ok my truck just got flashed this morning.
Reprogrammed PCM, FICM, ICM, OTC and wheel axle ratio, reflashed pcm and roadtested.
All I can say is WAAAAHOOOOO!!!
Truck idles and runs smoother, more pickup at lower rpm's, shifts down quicker when throttle is applied and turbo kicks in sooner. I'll say that if your truck isn't running smooth, this flash is for you. At least now I don't feel like I made a $42k mistake. It runs that much better!!
Cheers,
Bryce
PS
I'll update after I drive it a few more times.
Haven't really tested the Dead-pedal syndrome yet, but after a few more drives, I'll let you know
Cheers,
Bryce
__________________
  #24 (permalink)
Old 10-13-2003, 10:07 PM
diesels revenge is starting off with a positive reputation.
I have the cure for you guys this pedal is awesome quickie throttle no more dead pedal it helped my ET'S at the drag strip too.
  #25 (permalink)
Old 10-15-2003, 03:22 PM
FTE Ken's Avatar
Administrator
FTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputation
Motorhaven, the store that supports this site, has the same pedal for less. 1-877-399-6417
__________________
Ken Payne
Gone Fishing...
LACK OF PLANNING ON YOUR PART DOES NOT CONSTITUTE AN EMERGENCY ON MY PART.
2006 Roush F150 Project: Roush Supercharger, Troyer & My Tuning, 9lb pulley, Level 10 Trans, E-Fans, Oil Separator, Brandmotion GPS, BlueConnect Hands-Free Phone & iPod Direct Connect, Black Headlights & Taillights, Retrax Retractable Tonneau & more.
2004 F250 King Ranch Crewcab 4x4 6.0L PSD project: DP-Tuner Tuning and MBRP Stainless Dual Exhaust.
2000 Ranger Supercab XLT 3.0 V6 project: Bright Box, Mac Intake, Tonneau, my tuning.
RIP: 1967 & 1975 F100, looking for a 66 F100
  #26 (permalink)
Old 10-15-2003, 09:13 PM
IB_Tim's Avatar
Administrator
What is the mechanical or electrical advantage to the after market pedal.
This is very intriguing as to how and why it works…………taking away the dead pedal problem.
There has to be one of the above to make a difference.
__________________
Administrator
  #27 (permalink)
Old 10-15-2003, 09:14 PM
DWolf is starting off with a positive reputation.
ken or diesels revenge
I looked at the pedal add and do not understand how it can gain 10 hp or make a quicker pedal and is it a easy install?
thanks Don
Hi Tim it looks like you had the same question as I at the same time Don
  #28 (permalink)
Old 10-15-2003, 09:23 PM
FTE Ken's Avatar
Administrator
Here's the deal....
This is not a magic pedal that gives more power overall. It contains a more precise and accurate sensor that does not have the flat spot. Because of this, the PCM has better throttle response as the throttle passes through this region, resulting in slightly faster turbo spooling. You don't gain any peak HP (wide open throttle) but you do gain HP across this normally flat spot.
__________________
Ken Payne
Gone Fishing...
  #29 (permalink)
Old 10-15-2003, 09:26 PM
IB_Tim's Avatar
Administrator
thanks Don
Something here is very strange, from an engineering point of view I am having a bit of a problem fathoming success with a simple change of a part……………..there are so many different parameters that the pedal accomplishes. This is going to be real interesting. I am anxious to learn………..
Learn from the mistakes of others. You can't live long enough to make them all yourself.
__________________
Administrator
  #30 (permalink)
Old 10-15-2003, 09:31 PM
FTE Ken's Avatar
Administrator
That's why I said it doesn't increase HP overall. You'll just seen better throttle response in the flat spot due to the sensor providing a more linear reading to the PCM.
__________________
Ken Payne
Gone Fishing...
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
