Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
1973 - 1979 F-100 & Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
  #1 (permalink)
Old 10-07-2003, 12:50 AM
roan65 roan65 is offline
Garage is empty, add now
roan65 is starting off with a positive reputation.
cummins conversion
I'm thinking about putting a cummins into a a 78-79 f-250. I will be contacting fordcummins.com, but was wondering if anyone knows of any other people/places where I could get some info. Thanks
  #2 (permalink)
Old 10-07-2003, 09:07 AM
BigBully BigBully is offline
BigBully is starting off with a positive reputation.
Ya Me!
__________________
79 F150 4x4 500+ci
79 F350 4X4 5.9 Cummins Twin Turbo
97 F350 4x4 CR Cummins Twin Turbo
  #3 (permalink)
Old 10-07-2003, 07:13 PM
Scot Scot is offline
Scot is starting off with a positive reputation.
I am doing one.
__________________
'78 F250 4x4 Supercab, Cummins 6bta, NV4500, South Bend clutch, NP205, Dana 70/60. Click on my gallery for lots of build pictures.
'55 F100. 302, Tremec TKO, 9" 4.11 LSD, A/C P/S, disc brakes, cruise, arrest-me red. On the road since 1989.
  #4 (permalink)
Old 10-07-2003, 09:53 PM
Ive had mine done for about 6 months. I would like to know how yours is going. I took a bunch of pics today and Im going to post them on my web page after while.
__________________
79 F150 4x4 500+ci
  #5 (permalink)
Old 10-07-2003, 11:51 PM
Sweet, What "extra" parts am I going to need?? motor mounts I assume, fuel tanks ect....
Bigbully, how well does it work?? was it worth doing?? What kind of milage are you getting? how does the front end handle it?
__________________
"Plowboy" - 79 F-350, SRW, 4X4, 400 & C6
"Roan" - 65 Mustang resto-mod, 5.0 & T5
"Ugly" - 77 Bronco, 302 & C4
  #6 (permalink)
Old 10-08-2003, 12:33 AM
WOW what extra parts?, Thats a loaded question.
It works real well and yes it was worth doing. I went from a Hopped up 460 getting 3 to 6 MPG to 15 to 21 MPG(Depending on Right foot pressure) The front handels it real well. Its only 250 pounds heavier then the 460. You will need alot of parts and you will have to fab a few parts. If you cheat and use the Dodge Tranny it will be cheeper. The Power is Unreal with the pump turned up. Alot more Power then the 460 had alot better Milage. Stock it was a pig but a few adjustments to the pump and WOW. I figure i'm at 250HP and around 600Flbs of torque. Im going to Dyno it next month and I will know for sure. I just put an address in my sig to pics of some of the conversion stuff.
Good Luck and have fun with the project.
__________________
79 F150 4x4 500+ci
  #7 (permalink)
Old 10-08-2003, 08:20 AM
grapegravy's Avatar
grapegravy grapegravy is offline
grapegravy is starting off with a positive reputation.
Thanks alot guys, just what I needed, one more thing to consider. And the hamster wheel starts spinning,,,
__________________
1977 F-350 Supercab
Dan
  #8 (permalink)
Old 10-08-2003, 09:09 AM
hillbillyk hillbillyk is offline
hillbillyk is starting off with a positive reputation.
where did you get the motor mounts, or did you make them? Did you use the conversion from fordcummins? Did you have to do anything to get it to fit with the air conditioning box and the turbo? I am collecting parts to do the same swap in a 78 f-250 supercab 4x4. Having trouble finding the dodge 5 speed, they are like hens teeth.
  #9 (permalink)
Old 10-08-2003, 10:31 PM
I built my mounts. I believe they are being sold now. You will have clearance problems with the turbo and stock A/C air box. Others have flipped the exhaust manifold and that supposedly gives you enough room. I am going to run a no factory A/C cab and use a Air-Tique king-cool. The engine is long and will need all of trhe room you have. Do a search on www.turbodieselregister.com for "Randy at Reliable Diesel" in AZ. He is supposed to have done a bunch of these.
BigBully, What intercooler are you running?
__________________
  #10 (permalink)
Old 10-08-2003, 10:35 PM
Quote:
The motor mounts are the stock ones used on a 93 Cummins. The mount Towers had to be modified But it was real simple.
I used nothing from FordCummins.com . The Air Conditioning box Is another Story. Yes it has to be Highly Modified But I may have learned something new after I got it done. If you get a Low Mount Turbo Off a Factory Ford Truck Cummins 5.9 I think it will clear the A/C Box. The Front Crossmember has to be Modified Too, I had to cut 2 1/4 Inches out of it and box it back in. I had to fab a A/C Compressor Bracket and Weld a Pully onto the Cummins Fan Pully to run it, I also made a bracket for the Alternator and Used a Pully from the Dodge Alt. Radiator Hoses Now that was Fun.
Good luck Its alot of work, More then you realize. It took me 30 days @ 15 + - Hours per day to complete
__________________
79 F150 4x4 500+ci
  #11 (permalink)
Old 10-13-2003, 05:26 AM
335clevo 335clevo is offline
335clevo is starting off with a positive reputation.
Big bully,
Just interested, I have had a little bit to do wit cummins diesels fittes to heavy vechiles and they have been plagued with problems, the old 903's and similar ar chronic oil leakers, no matter how many times you fix them, several of the inline sixes spun main bearings and the new signature series are constantly comming back to the dearlership for warranty work. Does you cummins have oil leak problems or have I just been unlucky and got bad ones in the past?
  #12 (permalink)
Old 10-13-2003, 09:52 AM
When I first put it in I used Delvac oil and it started leaking so I changed to Valvoline and it has pretty much stopped but there is still a small leak. My friend has three 5.9s and as far as I know none of his leaks and the one has 336,000 miles on it. He is the one that told me to change from the Delvac Because he has always heard of it makeing them leak.
__________________
79 F150 4x4 500+ci
  #13 (permalink)
Old 10-13-2003, 04:58 PM
Never heard of Delvac making one leak. I have been running Delvac 1300 in my '93 Dodge since I bought it @69K miles. The truck leaks nothing and only uses a quart every 5K miles. Current mileage 186K.
Running synthetics will cause a small leak to turn into a large one and a large one turn into the Valdez.
__________________
  #14 (permalink)
Old 10-13-2003, 09:16 PM
Thats just what I was told and i see less leaking since I changed to Valvoline.
__________________
79 F150 4x4 500+ci
  #15 (permalink)
Old 10-13-2003, 09:45 PM
bigbully, I looked threw your pics, nice job!! Did you have to cut your cross member down?
That is interesting about the Delvac. I usually use dino-oil, but I have thought about switching to Delvac though. Many of the truckers around here use it. ...then again maybe I won't!
what did you guys do about fuel tanks??
Tags
2003, 59, ac, bracket, buy, clutches, compressor, conversion, conversions, cummins, dodge, f250, ford, motor, mount, mounts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
