Non Starting V-10 F53 Motorhome
On again off again. For the past 6 months my motorhome has normally started. However, on some ocassions (all cold) the motor cranks normally but will not fire. I've checked fuel pressure and it is fine. A couple of common things I've thought of. Won't start after completely filling the gas tank? After a rain? I've got a OBD II reader and I'm not getting any codes but today I did get a TC1 - P code that I've been unable to find in my manual. The service engine soon light is staying on during anytime the key is in the on position. The RV forum suggested checking out the cam sensor. Any thoughts?
I've done the battery cable thing. No help. I've done the gas pedal. The PID shows the proper voltage change.
My scanner may not be accurate. Gives me strange readings at time.
I made a appointment for October 20th to have the motorhome towed to a local RV repair shop. I hope the thing will start before then so I don't have to have it towed.
I'll keep checking the codes. It is drying up and warming up here so maybe . . .
