Shell Rotella synthetic 5w40
I was going to use Mobil Delvac 1 in my PSD,but can't get it locally.I can get it online,but don't want the hassle of shipping cost, etc. I'm considering using Shell Rotella synthetic 5w40,as I can get it at most Wal-Marts. Is this oil a good choice,or should I use another brand? Thanks.
Any kind of synthetic or synthetic blend 5W40 should be just fine. Just make sure it has the API certification trademark on the container CH-4, CH4/SJ, CH4/SL or DHD-1 if CH4 oil is not availalble, CCG-4 is acceptable. FWIW, Ford recommends 10W30 unless towing with ambient temperature above 50 F (10 C), then they recommend 15W40
Any synthetic oil will probably hold up well as long as it meets the specs for diesel engines. I started using the Rotella T Synthetic just recently due to the lower cost. I believe Delvac 1 is superior, but changing the oil every 5k due to warranty issues gets costly at $20 a gallon. If extending drain intervals is the goal, then I would use the Delvac 1. I would still do oil analysis however. Until then, Rotella is a proven diesel oil and will work just fine. I'm sure some will swear by Rotella and insist it's the best. I just like the Mobil synthetics better for extended drains.
Vijay
25
04-21-2010 05:34 PM
