2001 explorer Oil Pressure Sending unit location? - Ford Truck Enthusiasts Forums
Old 10-05-2003, 11:28 PM
ledbetter ledbetter is offline
ledbetter is starting off with a positive reputation.
I have a 2001 Explorer (4.0L 6V SOHC 4WD) with an erratic oil pressure gauge, which causes the "Check Gage" light to come on and eventually go off. I've done a search in the forums and found that it might be the oil pressure sending unit. Where is the unit located in the Explorer? (I've done a search and found the location of the units for other model trucks and SUVs but not the 2001 Explorer.)
Thanks for your help.
Old 10-06-2003, 06:54 PM
Dialtone Dialtone is offline
Dialtone is gaining momentum as a positive member of FTE.
Crawl under the vehicle and locate the oil filter. As a general rule, the senders are located in this area.
Dialtone
Old 10-06-2003, 07:51 PM
Thanks!
Old 11-06-2003, 01:48 PM
catamount catamount is offline
catamount is starting off with a positive reputation.
I once had a Thunderbird had a similar problem. The "Low Oil Pressure" alarm kept going off. I replaced the sending unit several times, then found out that Ford had a service bulltein that recommended an in-line resistor be connected to the sending unit--Ford part. This was a simple and inexpensive fix to an irritating condition. The sending unit required a special socket, available at Sears or Pep Boys, etc. No trouble replacing that, either.
oil sending unit fooledagain 1987 - 1996 F150 & Larger F-Series Trucks 8 10-01-2012 09:15 AM
Oil pressure guage intermitent 2001 5.4L RoscoeT 1997 - 2003 F150 9 08-13-2012 05:14 AM
4.2 oil sending unit location ARK Ranger 1997 - 2003 F150 2 02-11-2012 01:39 PM
Oil pressure sending unit bad? Explorer Freak 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 03-29-2010 12:34 PM
Oil pressure Gauge sticking on cold start Snaderi Explorer, Sport Trac, Mountaineer & Aviator 11 04-13-2004 10:19 AM
Tags
2001, 2003, 40, 40l, explorer, ford, located, location, oil, pressure, replace, sending, sport, trac, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
