:'( '94 F150 5.0 runs rough after tune-up - Ford Truck Enthusiasts Forums
Old 04-30-2001, 08:59 AM
wgroper wgroper is offline
wgroper is starting off with a positive reputation.
Just bought a really sweet '94 F150 XLT 2wd LWB EAOD pickup with 92K on the clock. It's loaded with everything you could get and the cool two-tone cream/copper paint ala Eddie Bauer. It has never had a tune-up, so I commenced on it yesterday morning. Installed new Autolite plugs, PCV valve, air filter, Accel Super Stock Spiral Wound 8mm wires, distributor cap and rotor. Since completing this work, the truck doesn't run for spit. It has a very bad idle, and almost quits under load. Is there a problem with the wires and the electronic ignition?
Also, I picked up a fuel filter and breather filter as well, but for the life of me I can't find where the breather filter is located. It appears the PCV system gets it's air for the intake air which has already passed through the air filter. Does this model even require a breaher filter? I'm thinking it does not.
Thanks for the advice!
Greg Roper
Old 04-30-2001, 12:04 PM
cgl cgl is offline
cgl is gaining momentum as a positive member of FTE.
I'm not sure about the stuttering, but there is a breather filter. Try checking your airbox. Open it up and look under your air filter.
Old 04-30-2001, 12:08 PM
I have removed the air filter and there isn't a breather filter there.
Old 04-30-2001, 06:18 PM
[font size="1" color="#FF0000"]LAST EDITED ON 30-Apr-01 AT 06:19 PM (EST)[/font][p]Gee, you'd think that the new edition of the Haynes manual would have the correct firing order in it, wouldn't ya?
I know, I know. I should have compared/labeled/replaced one at a time to make sure the firing order was right. A frustrating lesson learned.
BTW, the Haynes manual indicates one firing order for 95 and later and another for 94 and earlier. Mine is a 94 and uses the one labeled for 95 and later. I signed up for a subscription to www.alldatadiy.com and downloaded the TSB for correct wire routing to avoid cross-fire on the 302.
Old 04-30-2001, 07:54 PM
keith w's Avatar
keith w keith w is offline
keith w is gaining momentum as a positive member of FTE.keith w is gaining momentum as a positive member of FTE.
What is the breather filter for? xtal_01 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 12-01-2016 01:03 PM
Can I delete the PCV and run filters on the covers? mvvette97 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 01-11-2015 12:18 AM
Hooking up PCV breather to vacuum signal? breno1987 1987 - 1996 F150 & Larger F-Series Trucks 2 06-20-2011 12:17 AM
oil-breather cap question F250kid 1973 - 1979 F-100 & Larger F-Series Trucks 22 09-13-2005 12:19 PM
'94 F150 5.0 runs rough after tune-up wgroper Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 04-30-2001 09:47 PM
Tags
50, 94, f150, rough, running, runs, tune
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
