good trade
What kinda gas mileage you get now? I would bet it would stay the same or pretty close. It would allow your engine to work a little easier, with that cam and stock converter you aren't allowing the motor to begin to reach decent torque output, more likely than not so it has to work harder. You could alway go with an AOD. That would help ofset the higher stall and gears and make cruising more tolerable. Later
i don't really know the mileage now i said it was a beater truck the gas tanks are screwed up also so i have a boat 6 gallon tank in the toolbox with an electric pump hooked to it. it does not last that long. i have an aod from the 90 f150 but before i took it out it always started bucking when i behind a slow bus going about 45. when i got my foot on the gas a little and let it shift out of od it would work fine. do you think that was the torque convertor or the clutches slipping or what
