Motor Noise
Motor Noise
I have a 1998 f-150. I have notised that if you get on it, When the motor gets high rpm then you can here noise comeing from the motor. Is this normal? Somebody told me that all fords do this, but he drives a chevy. Shows how much he knows. The noise is like a pinging noise not really a taping noise. I never thaught it would be this hard to describe a noise. Please help.[QUOTE]IF YOUR GONNA BE A BEAR, BE A GRIZZLY!!! [COLOR=crimson][IMG]C:\truck\P9200014.jpg[/IMG]
Me too... f-150 Lariat 4.6 1998
I too have pinging under moderate and hard acceleration. I am looking for suggestions as how to remedy the problem. Some specifics: I tried a few bottles of injector cleaner and higher octane fuel - no change. Any hints?
P Brown
1998 Fully dressed Black and Tan F-150 Lariat. 4.6l, K&N, Flowmaster 40 series exhaust, 68k miles
P Brown
It's hard to diag spark knock without looking at the fuel trims and the MAF baro.
In most cases when you have spark knock and it doesn't go away with higher octane gas you probably have a MAF bad, BUT it's not always true........you could have carbon build up on the piston in which case you would need to de-carbon the engine.
I have the same problem in my 01 van. I had one service guy ride with me and he acknowledged the noise but was clueless as to it's cause. His only suggestion was the detonation thing mentioned above. Of course he also said that my belt was fine and didn't need changing. So I squeeled my van to a different dealership 3 days later where they found that both the belt and tensioner needed replacement. I plan on taking the van back to the 2nd dealership to investigate this sound and see what they say.
Originally posted by Fordtrucktexan
How do you clean the MAF?
I know people say you can.......but....it's pretty bad for the sensor
BUT! if you do clean it......LET IT COOL DOWN!!!!! that little bugger gets HOT AS HECK........once it's cold....try some electrical cleaner you find at radio shack or so and just spray it.....don't use a q-tip like people say.....thats useless
