E4OD Boil Over
E4OD Boil Over
I have a '94 Bronco with a 351 with 157,000 miles. My serpentine belt broke. I drove 4 blocks, until the temperature gauge went to the top. Tranny fluid started boiling out the filler tube, as well as coolant from the coolant oveflow container. I stopped two blocks from home. Walked home, got another vehicle, got a new serpen
tine belt and installed it(an hour later). The engine started up, ran cool, but tranny fluid still boiled out of the filler tube. So I had it towed home for $50 for two blocks. Do I need a rebuild ? The tranny never slipped or shifted rough before this, as on my '90 Bronco E4OD before it needed a rebuild.
You tranny experts, please let me know your thoughts. Auto trannies are the only thing I haven't rebuilt on vehicles.
Thank you,
Elton
Thank you,
Elton
Maybe you boiled too much tranny fluid out and now it's low.
Mine started to boil out through the filler tube and when I Stopped and checked it, it turns out I was WAY LOW on fluid and it was foaming out. I topped it off and all was well. Mine was low enough to foam but not low enough to cause shifting problems.
Just a guess though, is your fluid level ok? Is it shifting rough or slipping now???
EconolineFan
22
06-25-2019 04:18 PM
shawn1975
05-10-2015 08:55 AM
breesegabe
03-06-2012 04:49 PM
