M5od-r1 & R2 - Ford Truck Enthusiasts Forums
M5od-r1 & R2
Old 10-04-2003, 02:18 AM
red_rocket's Avatar
red_rocket red_rocket is offline
red_rocket is starting off with a positive reputation.
M5od-r1 & R2
Does anyone know if the tail shafts from these two will interchange?
the reason being is when I bought my BII as a roller, it had a R2 in it, bolted to a 13-50(maybe a 13-54) T-case.
I've never seen any adapter advertised to mate the two, which is Why im trying to figure out how the previous owner mated them.
Thanks,
Jared
1981 302 specs 460jared96 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 0 03-15-2015 06:08 PM
4R100 Vs. ZF6 grizzly11 1999 - 2003 7.3L Power Stroke Diesel 8 03-08-2012 09:31 PM
Jared Placermike Washington Chapter 24 04-18-2008 03:04 PM
208 case rebuild Ford_Six Clutch, Transmission, Differential, Axle & Transfer Case 1 11-04-2002 05:15 PM
Clutch jared Ranger & B-Series 4 10-06-2000 11:10 AM
Tags
adapter, blocking, interchang, m5od, m5odr1, r1, r2, removal, ring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
