93 F150 No power, low gas mileage. - Ford Truck Enthusiasts Forums
Old 05-21-2001, 04:55 PM
shawnb shawnb is offline
shawnb is starting off with a positive reputation.
I am posting this for a friend who has a 93 F150 5.0L with E4OD tranny and 137,000 miles.
He is experiencing no power "doggy" and getting only 12 miles to the gallon. He has replaced all of the sensors, with no improvements. Recently while checking the timing, for the first time, he discovered that the SPOUT connector was missing and the timing was set at 22 degrees. He promptly got a SPOUT connector and set his timing to 13 deg. After setting the timing he noted that his timing moves from 10 deg. to 16 deg and back again, this does not change when the SPOUT conn. is removed. He is getting frustrated with all of the work and no improvement. Could it be in his control module? Has anyone had his problems? Any and all suggestions will be considered.
Old 05-22-2001, 02:23 PM
larry derouin larry derouin is offline
larry derouin is starting off with a positive reputation.
Keep the SPOUT CONNECTED (except to set initial timing). The SPOUT is a advance cut out for setting initial timing. Once the initial timing is set re-connect the SPOUT and let the computers advance and retard the timing like it's supposed to.
As for the low power and Sucking down gas like a kid drinking Coca-Cola.........Usual tune-up stuff and pay particular attention to vacuum lines, and connectors, the vacuum can (coffee can), and EGR. Clean or replace the EGR, check the coffee can for splits or rusted holes (esecially around the end seams.)
Make sure all the sensors are working, and the Catalytic converters are not clogged. (Check this with Vacuum gauge. Look in Chiltons/Haynes for test details).
Tire pressures, bearing tensions, etc.
Larry
Old 05-22-2001, 10:47 PM
jakegypsum's Avatar
jakegypsum jakegypsum is offline
jakegypsum is starting off with a positive reputation.
It sounds like it could be a CAT problem.
Jakegypsum // Ford fleet, soup to nuts.
Old 05-23-2001, 09:52 AM
kwing kwing is offline
kwing is starting off with a positive reputation.
Also remember to erase the trouble codes. The easiest way is to disconnect the battery for a few seconds (you will need to reset your radio and clock again) or if you have a code reader, end the code test before it is finished reading the KOEO codes. The truck may run funny for a few minutes until the computer relearns the parameters. Drive it around then retest the trouble codes again.
If you have a code 111 you are all set, otherwise do more troubleshooting. Good luck.
Old 05-24-2001, 06:48 AM
Steverino Steverino is offline
Steverino is starting off with a positive reputation.
Low gas mileage can also be caused by worn ball joints and a front end that is badly out of alignment. Not uncommon for a truck with 137,000 miles.
Check the basics, such as:
new fuel filter
new air cleaner
spark plugs
clean the contacts on the inside of the distributor cap.
make sure spark plug wires are clean and not arching
set ignition timing
change the motor oil and the filter (good for 1 to 2 mpg for first 500 miles)
Old 05-24-2001, 09:10 AM
chip58 chip58 is offline
chip58 is starting off with a positive reputation.
I'm curious as to why the "coffee can" would effect mileage. Doesn't the ecm cut off vacuum to the evaporative emissions system shortly after the system is purged at startup?
Old 05-25-2001, 10:36 AM
[font size="1" color="#FF0000"]LAST EDITED ON 25-May-01 AT 10:39 AM (EST)[/font][p]The coffee can is a vacuum "RESERVOIR". Some accessories require a semi-constant vacuum supply and this levels out theplaying field between the intake manifold and the accessories.
One side is directly connected to the manifold vacuum (side with check valve) and the other side is connected to the evap system (no check valve)and suppplies other vacuum accesories.
If the can is wasted (split, corroded, or otherwise breached) then you get a constant vacuum leak, like if you took off a vacuum line from the manifold. It'll run but it'll run like #$&^.
I was getting about 10mpg and rough idle on my '87. noticed that the top of the "CAN" was split and was leaking.
Changed out the can with a new one from Dealer ($47.00) and idle smoothed out and gas mileage went to 13-14. NO CHANGE IN DRIVING HABITS.
Larry
Old 05-25-2001, 10:53 PM
gamehunter gamehunter is offline
gamehunter is starting off with a positive reputation.
hey lary, what size engine do you have? I just bought a '90 1/2 ton 4x4 reg. cab long box with the 302 and it is getting 12.7mpg last time I filled it up. (tonight) This is with 30 miles to work on highway and in town use. It has been used more in town than out so it should be over 13 when i get more highway miles instead of intown. I figure it was getting about 10-11 in town before i started work out of town. The truck has a dual exhaust but I don't know what kind because it was there when I bought it. I know fords suck gas like no other truck but is this about right? Im thinking about adding an FIPK and a Superchip. Mostly to increase power but the added gas helps too. Thanks
Old 05-25-2001, 11:28 PM
92f150 92f150 is offline
92f150 is starting off with a positive reputation.
map senson has some to do with timing i know it can make an idle roll but not exactly how much it has to do with timing
Old 05-26-2001, 02:46 PM
[font size="1" color="#FF0000"]LAST EDITED ON 26-May-01 AT 03:13 PM (EST)[/font][p]gamehunter:
totally stock '87 f-150, standard cab, long bed, 4.9 L6, T-18b 4spd, 3.55's.
113,800 miles, no leaks, no smoke, ALL GRUNT!!!!
This is my 1st ford in over 15 years. The only one I had with a v-8 was wife's 1st car, a '65 Mustang 289/2V(she was original owner). The motorcraft Carb was a piece of #@&^%*$!! Hard to start in AM, crap for Gas mileage (sub 10). Got an adapter plate and put a Rochester 2-GC with a manual choke and got better than 18 on the highway and 14 in town. Ran cleaner (had it sniffed and passed 1984 standards for FED.) and was easiest thing to start in the morning. 1/2 a pedal, pull choke, let off pedal and crank for about 3 seconds. Never had any problems with that car afterwards.
all the rest have been L6 cars. Love the inline 6. Had 2 '61 Falcons, 1 with a 144, and 1 with a 170, a 66 mustang with a 170, a 78 granada (wife's also) with a 200. Never had a lick of problem with any of them.
And I'll ADMIT to having a 1958 Chevy Biscayne, a 60 Chevy Belair, a 62 Rambler American 400 Station Wagon (reclining front split bench and a drive-in....WHOOO HOOOO) and a 67 C-10 Short Bed PU ALL with INLINE 6's.
Larry
Old 05-27-2001, 12:39 PM
Larry;
Is there any chance you put a vacuum guage on your 300 before you changed out the can? Mine's pulling 19" at idle, so I don't think I've got a leak, but I'm curious if you did a before and after.
Old 05-27-2001, 01:42 PM
pigsew pigsew is offline
pigsew is starting off with a positive reputation.
460 f350 high idle wont idle without spout ThatFordGuy 1987 - 1996 F150 & Larger F-Series Trucks 5 04-10-2015 08:38 AM
Timing 5.0 & TPS Testing Glenn.b1 1987 - 1996 F150 & Larger F-Series Trucks 4 02-06-2015 07:44 PM
'94 F150 5.0 pinging in closed loop, under load in open loop spreng37 1987 - 1996 F150 & Larger F-Series Trucks 11 10-25-2014 03:28 PM
spark advance not working dtford 1987 - 1996 F150 & Larger F-Series Trucks 6 03-18-2008 11:13 AM
distributor spout connector? 1995 f-150 5.0 4x4 manual tranny gino93 1987 - 1996 F150 & Larger F-Series Trucks 6 05-19-2000 07:28 PM
Tags
1993, 302, 93, accessories, bad, f150, ford, gas, gass, improve, lack, low, milage, mileage, mpg, power, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
