frames
Old 10-02-2003, 07:18 PM
tcheney's Avatar
tcheney
tcheney is offline
frames
i have a 89 fullsize bronco body rotted very bad but drivetrain perfect (5.8) automatic frame and suspension
great. also have 87 f150 (4.9) 4 speed. body excellent
frame rotted beyond repair (at the spring shackels)
my question is ? will the body of the f150 fit on the bronco frame?
-All capse removed by Admin-
Old 10-02-2003, 07:41 PM
zieg96's Avatar
zieg96
zieg96 is offline
I believe the wheelbase is shorter on the Bronco but not positive. I would measure the bodymount locations and compare.
Old 10-03-2003, 12:13 AM
RYCAN1's Avatar
RYCAN1
RYCAN1 is offline
It is possible to put together . You will have to shorten the box but the cab mount should work .Good luck!
ryan f150 4x4
1978 - 1996 Big Bronco
06-24-2021 09:56 PM
JPETRO1051
10-17-2009 09:25 PM
njtinman2
02-08-2005 12:16 PM
Quick Reply: frames
