Installing a Tach on a 89 F250 w/460 (where to wire the pick-up) - Ford Truck Enthusiasts Forums
Old 05-13-2001, 08:50 PM
noremac19 noremac19 is offline
noremac19 is starting off with a positive reputation.
Old 05-27-2001, 09:12 PM
bigmikef250 bigmikef250 is offline
bigmikef250 is starting off with a positive reputation.
Can anyone help me, I want to install a tach in my 89 F250 that has a 460 and 4WD. My question is which wire on the coil do I hook the tach's pick-up to? Coming from the coil there are two dark green/w yellow strip wires that I think are the correct ones but am not sure since my Chilton's manual doesn't contain a good wiring diagram of the coil.
Also, is there anyway to wire into the harness under the dash or am I out of luck since my truck came w/o a tach (there might not be a pick-up already wired to the coil?)
Any help would be greatly appreciated as I can't stand not
having a tach on a manual vehicle
Thanks,
-=Bigmike
Old 05-28-2001, 01:26 AM
CantDrive55 CantDrive55 is offline
CantDrive55 is starting off with a positive reputation.
Yeah, it should be the green with yellow stripe. One of the green wires goes to the distributor and the other is shown passing through a 1.8k resistor on the way to the tach. I'd guess the resistor is only for ford's tach, and should not be needed for an aftermarket one. Got this our of a Haynes manual.
Old 05-29-2001, 12:26 PM
Thanks for the help, I'll give it a shot this coming weekend and report back with my results.
-=Bigmike
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 04:27 PM
ooops Aerostar 5 01-14-2015 04:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 07:14 AM
Salvage yards Oklahoma Chapter 14 04-11-2003 11:33 PM
Superchargers walterdanek Ford Inline Six, 200, 250, 4.9L / 300 16 02-16-2001 08:56 PM
Tags
460, 89, diagram, engine, f250, f350, for86, ford, install, tach, w460, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
