correct spark plug gap for a 93 f150 5.0
Old 05-18-2001, 08:00 AM
dee's Avatar
dee
dee is offline
would any one happend to no the the correct gap for the motorcraft plugs for a 93f150 5.0 i was told 0.54 by the auto part store is this correct. thanks
Old 05-18-2001, 08:54 AM
PAUL_2's Avatar
PAUL_2
PAUL_2 is offline
Dee, There is a sticker under the hood that should tell you the correct spark plug gap , I beleive for your engine it is .044 to .046 . 054 sounds like a little too much , the info on the sticker will be correct .
Old 05-18-2001, 08:57 AM
Avanti's Avatar
Avanti
Avanti is offline
Chiltons lists .044 as the gap for the 93 5.0.
Old 05-18-2001, 12:48 PM
dee's Avatar
dee
dee is offline
thanks for the info, i no .054 sound like to much
Old 05-18-2001, 04:33 PM
pickupman's Avatar
pickupman
pickupman is offline
[font size="1" color="#FF0000"]LAST EDITED ON 18-May-01 AT 05:33 PM (EST)[/font][p]I have a 92 F150 with a 302 and a 92 Grand Marquis with a 4.6 and both are gapped at .054. What does the sticker under your hood say it should be?
Old 05-19-2001, 10:57 AM
Pastmaster's Avatar
Pastmaster
Pastmaster is offline
My 93 302 says .052-.056 on the underhood sticker. I think when I was still using the factory ignition setup, I set it at .054 to be safe.
Old 05-23-2001, 06:20 PM
hotrodmex's Avatar
hotrodmex
hotrodmex is offline
Old 05-30-2001, 08:14 AM
kwing's Avatar
kwing
kwing is offline
Just bought a set of NGK plugs at the auto store. They are pre-gapped at .054. The AUTOLITE plugs (FORD) are also pre-gapped at .054. The underhood sticker says .054-.056. The Haynes manual says, however to use .044??!! Stick with the underhood specs and the pre-gapped settings. If u are using a high energy ignition and wire set then I would gap them a bit wider as well.
Old 04-02-2009, 06:43 PM
whitemfox's Avatar
whitemfox
whitemfox is offline
what is the correct timing for a 90 f150 4wd 5.0 engine and where exactly is the marks I found a large on one but no little ones so is the large one right. i had to pull the dist out to change the module and forgot to mark the dist.
Old 04-03-2009, 08:37 AM
jas88's Avatar
jas88
jas88 is offline
10 degrees BTDC, the scale is on the passenger side of the block.
Old 04-03-2009, 06:12 PM
EPNCSU2006's Avatar
EPNCSU2006
EPNCSU2006 is offline
How did you find this thread from almost 8 years ago ?
solidrunner
16
07-28-2015 10:50 AM
copperjohnc
09-28-2011 11:02 PM
jv2290
13
12-28-2010 10:11 AM
F.T.1223
06-04-2003 10:15 AM
smestas
05-26-2003 08:46 PM
Quick Reply: correct spark plug gap for a 93 f150 5.0
