1995 F150 - Hazard Flasher
Old 05-21-2001, 06:59 PM
Crash55's Avatar
Crash55
Crash55 is offline
The four way flashers on my truck are no longer working. I can not find the flasher for them though. Can soemoen tell me where it is? The only one I can find is for the turn signals. I have checked the multifunction switch in the steering column and it passes the continuity checks for the hazards.
Old 05-22-2001, 12:46 AM
charlez's Avatar
charlez
charlez is offline
If I remember, Ford likes to hide them. Look on the back side of the fuse panel. Basically right behind the turn signal one.
You might have to take a couple screws out and drop the fuse block to get to it.
Old 05-22-2001, 04:27 AM
hotrodford_88's Avatar
hotrodford_88
hotrodford_88 is offline
Also, they absolutely love to hide them behind & above the glove box! That's where the one is on my 88 model. So check there as well.
988 F-150, SWB, 5.0 EFI (formerly 4.9 EFI), M5OD 5 speed, 3.08 gears, Summit shorty truck headers, Custom built Flowmaster exhaust system. Force 4 LP6000 lightbar, Federal signal PA-300 100 watt siren, Icom IC-V100 50 watt mobile radio.
1965 F-100 (just purchased 1/18/01), SWB, 390, C-6 auto. Dual exhaust, Not much else to do to it.
Can see both below.
[link:www.geocities.com/hotrodford_88/|Hotrodford_88's Webpage]
Old 05-22-2001, 04:29 AM
walterdanek's Avatar
walterdanek
walterdanek is offline
Put your hazzards on, then listen for the clicking. That might help you.
Walter
Old 05-22-2001, 06:49 AM
87f250's Avatar
87f250
87f250 is offline
they don't work...how can he hear the clicking?
Old 05-22-2001, 07:59 AM
walterdanek
Sorry, thought you said the turn sig were not working, but the hazards were
Walter
Old 05-23-2001, 07:31 PM
Crash55's Avatar
Crash55
Crash55 is offline
I looked behind the fuse box and it wasn't there. Tried looking up under the dash with a flashlight but no luck. The service manual I have said it was either behind the fuse box or on a bracket at the end of the control panel. Couldn't locate the bracket. Guess the search will go on.
Old 05-23-2001, 07:39 PM
hotrodford_88
Did you try looking behind & above the glove box? That's where the one is on my 88 model F-150.
I guess Ford likes to hide them to where they are the only one's who can find them.
1988 F-150, SWB, 5.0 EFI (formerly 4.9 EFI), M5OD 5 speed, 3.08 gears, Summit shorty truck headers, Custom built Flowmaster exhaust system. Force 4 LP6000 lightbar, Federal signal PA-300 100 watt siren, Icom IC-V100 50 watt mobile radio.
Can see both below.
Old 05-25-2001, 12:55 PM
Crash55's Avatar
Crash55
Crash55 is offline
I looked behind the glove box yesterday and I saw nothing that looked like a flasher. There was an electronics box nect to the defroster vent duct but it didn't look promising.
Old 05-26-2001, 11:01 PM
hotrodford_88
Do you have a relay box under your hood? That is the only other place that comes to mind. I just remembered that, combined with the fact that yours is a 95 model, is where it "could be"
Let us know if you find it.
Can see both below.
Old 05-27-2001, 12:09 PM
Crash55's Avatar
Crash55
Crash55 is offline
There is a power distribution box under the hood taht has relays in it. Looked in the owner's manual and in the box itself but didn't find teh flasher there.
Old 05-31-2001, 12:55 PM
Crash55's Avatar
Crash55
Crash55 is offline
I found it. It was on the back of the fuse box opposite the turn signal flasher. The reason I missed it the first dozen times was because there was no flasher in it!! Evidently teh previous owner removed it for some reason.
Old 05-31-2001, 02:28 PM
dtoolman38's Avatar
dtoolman38
dtoolman38 is offline
Old 12-16-2013, 01:34 PM
gizmo6958's Avatar
gizmo6958
gizmo6958 is offline
Blinkers/Flashers/brake lights not working
96 F250, 7.5, 4X4, blinkers/flashers and brake lights quit the other day. Just replaced both flashers on the front and back of the fuse box, still nothing. High brake light above the cab still works however? Any thoughts?
Thanks, gizmo6958
Old 12-16-2013, 03:01 PM
White Max's Avatar
White Max
White Max is offline
With those symptoms, I'd be looking toward the MFS.
Quick Reply: 1995 F150 - Hazard Flasher
