.056 or .044 gap??
I believe that the manual says that if the emissions sticker under the hood is different than the manual, you should go with the under hood sticker. In my case (92 - 302) it is the larger gap, so that is what I put in. The only problem for me was that I had a crossfire problem in the 7 and 8 cylinders, that I thought was a plug problem, (so I tried both gaps,) but was really the 7 & 8 wires having been routed too close together. Once I seperated them, the truck hasn't crossfired once, and the engine seems to run good with the larger gap plugs.
Eric.
92 F-150, Supercab, 4x4, 302, M5OD
Eric.
seismojones
1983 - 2012 Ranger & B-Series
11-19-2003 06:11 PM
john
01-04-2000 06:46 PM
