Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 09-29-2003, 05:00 PM
restoreman restoreman is offline
Garage is empty, add now
restoreman is starting off with a positive reputation.
distributor conversion
I'm wanting to convert my 1937 ford distributor to a stand up type. Is this a fairly easy swap? Or is this a difficult swap? Any information and thought will be greatly appreciated.
Thanks, restoreman.
  #2 (permalink)
Old 09-29-2003, 06:26 PM
46fordtruck's Avatar
46fordtruck 46fordtruck is offline
1946 Ford 1/2 ton pickup
46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.
By stand up you mean the '49-'53 style of distibutor, right? It can be done, I know for sure you need the timing cover from a '49-'53 engine. Also, need to adapt the gear drive for the distibutor instead of the '37's stlye of driving the distributor. I'm sure there is more...but I can't remember. You may just be able to use 8BA gears and such to make the conversion.
__________________
Gary-
'46 Ford 1/2 ton
'07 Black F-150 XLT SuperCrew
plus a handful of other Fords
'42-'47 collector and aficionado
  #3 (permalink)
Old 09-30-2003, 05:07 PM
mantta's Avatar
mantta mantta is offline
mantta is gaining momentum as a positive member of FTE.
There used to be a kit available to make this conversion. You might want try a few of the antique auto parts dealers on the internet or maybe J.C. Whitney. First try Mac's Antique Auto Parts.
__________________
ENCS(SS), (SW), USN RET (E-8)
Keweenaw Bay, MI
U.S. Navy (Submarine Service) 60-80
2010 Ford F-150 4WD Lariat Ext Cab
1999 Lincoln Town Car Ecec Series
1930 Model "A" Coupe
  #4 (permalink)
Old 09-30-2003, 06:16 PM
Some of the best people I've ever dealed with for Flathead stuff is Patricks Antique Auto.
www.patricksantiquecars.com
I'd give the actual link, but the URLs here aren't working. Just cut and paste.
Give them a try...they are very helpful. Patrick should be able to help you figure out exactly what you need.
__________________
Gary-
'46 Ford 1/2 ton
  #5 (permalink)
Old 10-05-2003, 06:32 PM
2speed 2speed is offline
2speed is starting off with a positive reputation.
There are two different front covers for the 8BA. Aluminum and iron, and they take different distributors. I think that cam has to swapped out. The drive gear is press onto the 8BA cam, and the early engines don't have a provision for that I believe, although I'm don't know that much about the early engines. There are also two different cams for the 8BA. One for the standards valves, and a later one for rotable valves.
Tags
46, conversion, distributer, distributor, flathead, ford, stand
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
