P0176: Fuel composition sensor circuit
Old 09-29-2003, 12:45 PM
TJN's Avatar
TJN
TJN is offline
I just got a P0176 code on my 99' Ranger 3.0L Flex 4X4 offroad. The truck is running fine. Does anyone have any experience with the fuel composition sensor circuit?
Questions I could use answered:
-Where is it?
-Do I need it if I only run 87?
-Can you buy them or dealer only?
-Does this code mean the sensor is bad or bad wiring?
Old 09-29-2003, 09:15 PM
Rockledge's Avatar
Rockledge
Rockledge is offline
Hello TJN, welcome to FTE!
Code P0176 is related to your Flex Fuel Sensor and can be caused by one or more of the following:
l Open or short in FF sensor VPWR circuit
l Open in battery ground to FF sensor circuit
l Open in FF sensor signal circuit
l Short to ground in FF sensor signal circuit
l Fuel contamination
l Short to VPWR in FF sensor battery ground circuit
l Short to VPWR in FF sensor signal circuit
l Fuel separation
l Damaged FF sensor
l Damaged PCM
Also, you might want to read through this previous thread on the subject: Flex Fuel Sensor.
Good luck!
Old 10-01-2003, 09:00 AM
TJN's Avatar
TJN
TJN is offline
Thanks for that other thread. In the last month, I have had to have my computer reprogramed, replaced my mass air sensor, replaced my EGR sensor, and now this sensor.
Does anyone have any suggestions as to why I'm loosing sensors constantly?
Can you get these sensors at a junk yard, and will they work right with my computer?
Do you chance this sensor like a fuel filter?
Old 10-01-2003, 07:50 PM
Ken00's Avatar
Ken00
Ken00 is offline
I would wait until you run a few more tanks through it, look at the wiring for problems. You do need it for proper operation, the PCM uses the information. They are not a common failure but you never know with JY parts.
chris110587
18
03-18-2017 12:24 PM
2006powerstroke90
02-08-2012 01:25 PM
DIRTY NASTY G
09-02-2010 09:11 AM
michael smith
08-29-2008 02:57 AM
01silvergt
1997-2006 Expedition & Navigator
07-13-2005 02:08 PM
Quick Reply: P0176: Fuel composition sensor circuit
