1974 Camber and Caster Adjustments?
Old 09-29-2003, 08:04 AM
Native Gearhead's Avatar
Native Gearhead
Native Gearhead is offline
I have a '74 F-100 2WD with the TIB and Kingpins. On these older vehicles, is there a camber and caster adjustment? If not, what front end adjustments besides toe can be done?
Old 09-29-2003, 08:46 AM
73Custom's Avatar
73Custom
73Custom is offline
If the kingpins, springs and all the bushings are in good shape, there should be no need for camber/caster adjustment. They were not made with adjustable camber/caster, but it can be adjusted if need be - with a lot of work.
Marty
Old 09-29-2003, 10:18 AM
Native Gearhead
Thanks Marty...
I don't suspect any particular problems. I'm just going to give it a whirl at alignment. I got the front wheels balanced and I am good to go up and over 75mph, but I noticed what looked like a bit of "toe out" when I look at it from a distance. I did some reading, and think I can do that adjustment to at least get it closer.
Old 09-29-2003, 11:38 AM
plowpusher's Avatar
plowpusher
plowpusher is offline
a good alinment shop has the equipment to bend the I-beams to adjust caster/camber toe is adjusted with the adjustment sleevs on the tie rods
Old 09-29-2003, 06:34 PM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
Replace all of your suspension bushings with new rubber or polyurethane. Kingpin replacement is best done by a shop. Alignments can be done by a good heavy truck shop. The normal car alignment shops can not align one of these trucks.
BstangBill
09-22-2016 01:48 AM
rock2610d
10-20-2015 11:09 PM
gopher2
13
10-14-2012 04:47 PM
Dutter
1983 - 2012 Ranger & B-Series
05-17-2011 06:57 PM
7278ford
1978 - 1996 Big Bronco
10-22-2009 10:47 PM
Quick Reply: 1974 Camber and Caster Adjustments?
