Oil Filter on 99 F-150 4.6 Triton V8 - Ford Truck Enthusiasts Forums
Old 09-28-2003, 07:52 PM
denny seifried denny seifried is offline
denny seifried is starting off with a positive reputation.
Well, I just finished my first oil/oil filter change on my new-used 1999 Ford F-150, with the 4.6 Triton V8. Everything went smooth, until I tried to get the old filter (a Wix Filter) do drop out from around all of the obstructions, near the filter location.
I had the truck on my ramps, which I use for my all of my other oil changes on my cars. Since it was on the ramps and empty of oil, I couldn't move the steering wheel and move part of the steering arm, which was really in the way. After I tried about 50 different positions, with the old filter, I was finally able to coax it through, between a couple of parts. It was a little tricky to get the new Motorcraft filter back into position, also.
Any suggestions for the next filter change, to make it go smoother? Would I be better off, just crawling under the truck, while it is flat on the ground and not use the ramps?
My wheels were straight ahead, while on the ramps.
Old 09-28-2003, 08:21 PM
triton_2002's Avatar
triton_2002 triton_2002 is offline
triton_2002 is starting off with a positive reputation.
I did my own oil change on my 02 F150 5.4 and had a similar problem. It's just a real tight fit. I saw an oil filter wrench in the O'Reilly's Sunday ads that would probably help.
Old 09-29-2003, 09:13 AM
ggarrahan ggarrahan is offline
ggarrahan is starting off with a positive reputation.
Ah- you have found one of Ford's better ideas! Look out when the factiry adds a dribble tray, you know you are in for it then! I've never worked on any car or truck with a worse filter placement, but after doing it a few times you learn to put the vehicle on jackstands, turn the wheels, and get either a cap wrench or a thin strap wrench with a swivel!
Ramps wb6anp 2017 Super Duty 5 12-30-2016 07:50 PM
Simple Coolant Flush For The 6.0 Texas Bob 6.0L Power Stroke Diesel 1 11-04-2016 02:29 PM
PITA Oil Change JKBrad 2015+ F150 12 01-30-2016 04:32 PM
2008 Mountaineer AWD stkelly Explorer, Sport Trac, Mountaineer & Aviator 1 10-29-2010 05:12 AM
Sat. Oil Change W/ Chevron Supreme! Ed Oil & Lubrication 24 05-03-2006 01:06 AM
Tags
2001, 46, 54, 99, diagram, engine, f150, filter, filters, ford, motor, oil, series, systom, triton, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
