No Windstar dash lights - Ford Truck Enthusiasts Forums
Old 09-28-2003, 04:55 PM
kenpep2 kenpep2 is offline
kenpep2 is starting off with a positive reputation.
Lightbulb No Windstar dash lights
The other night, while driving all the instrument lights went out on my 96 Windstar. Flicking the headlight switch on and off made them come on for about 1 min., they blinked, and then went out for good. I checked out the fuses, they looked and tested OK. Tried a new headlight switch, still no lights. Tried a used dimmer switch from a junkyard, still no lights. I have power going to the dimmer switch all the time at terminals 1 & 2, and power to #3 when the headlight switch is turned on. So I guess that eliminates a fuse problem and the headlight switch possibility. Does anyone have any ideas? I probably should try a new dimmer switch, as I don't have proof that the used one was any good.
Any advice would be appreciated. Thanks!!
Old 09-28-2003, 07:28 PM
HomerWinzlow's Avatar
HomerWinzlow HomerWinzlow is offline
HomerWinzlow is gaining momentum as a positive member of FTE.HomerWinzlow is gaining momentum as a positive member of FTE.
You should be getting power to pin 5 if the switch is working..Light blue and red
Old 09-28-2003, 08:37 PM
Thanks, Homer. I'll give that a try. I saw that same solution for the same problem that someone was having with a 96 Ranger. I thought that the wiring schematics might be similar. Let you know how I made out.
Thanks again
2000 exp XLT interior lights stay dim when headlight or parking lights are on Colton92 1997-2006 Expedition & Navigator 0 11-23-2016 07:51 PM
1965 headlight problem mustangpt 1961 - 1966 F-100 & Larger F-Series Trucks 2 04-22-2015 10:59 PM
1965 Headlight switch wiring w5nra 1961 - 1966 F-100 & Larger F-Series Trucks 5 06-23-2014 07:47 PM
no headlights but have all running lights dutchhman Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 06-11-2010 05:52 PM
Dimmer switch and headlight problem? Sillbeer 1973 - 1979 F-100 & Larger F-Series Trucks 7 04-14-2008 07:04 AM
Tags
1996, 2000, 2001, 2003, alerts, dash, dashboard, ford, instrument, light, lights, panel, radio, windstar, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
