TSP Code 122 on 95 5.0L - Ford Truck Enthusiasts Forums
Old 07-10-2001, 01:41 PM
sdgrant150 sdgrant150 is offline
sdgrant150 is starting off with a positive reputation.
Ran the codes, got 122. Do I have to replace my TSP or can it be adjusted? If it needs adjusting,what is the best way to do so?
Old 07-10-2001, 04:16 PM
PAUL_2 PAUL_2 is offline
PAUL_2 is starting off with a positive reputation.
It may not be the sensor itself . Code 122 leans toward the wiring & or the electrical connection to the Tps Sensor . I dont believe they can be adjusted on your engine . Also check the throttle plates for carbon that may be holding them open enough to set the code . Whats the problem that lead you to check the codes ?
Old 07-10-2001, 05:47 PM
Brief History: Received a Check Engine Light. Blindly replaced the EGR and spark plugs. Light still on. Checked the vacuum system for leaks and operation including the EGR position and the EGR solenoid valve. Check engine light remained on. (acutally the light is off when I first start the truck then comes on shortly thereafter.) I then purchased a hand held sensor to read the codes. I received 122 with the KOEO test and received 122 and 998 with the KOER test. The manual that came with the code reader said the 998 code required the KOEO fault to be repaired before continuing.
I checked the wiring to and from the TPS and they look okay. I will check the throttle plates for carbon.
As background, the mileage is 130,000.
Many thanks for your assistance!
Old 07-10-2001, 07:47 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
clutch area chatter on 2001 F350 tsp skipstein 1999 - 2003 7.3L Power Stroke Diesel 2 09-02-2016 09:56 AM
Interior color change build (vinyl, plastic, metal pieces) gtanns 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 11-19-2013 11:54 PM
How to clean a gas tank. old broke prospector 1961 - 1966 F-100 & Larger F-Series Trucks 9 09-26-2013 04:33 PM
Code 122 - TPS faulty or need of adjustment? kfud 3.0L V6 1 03-16-2004 07:01 AM
Tags
122, 1994, 2010, 95, check, code, econoline, engine, explorer, f150, falt, ford, fseries, sensor, superduty, tsp
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
