Any Ford V8's with the distributor in the rear? - Ford Truck Enthusiasts Forums
Old 09-28-2003, 02:05 PM
PhatCaprice's Avatar
PhatCaprice PhatCaprice is offline
PhatCaprice is starting off with a positive reputation.
Overheard a conversation that some dude knew some guy with a Ford V8 with the distributor in the back in the engine. One of the guys called bull on this and said that all the Ford V8's have them in the front. Then some moron said "unless he's got a chevy in that Ford truck.", blah blah blah. Got me to thinking though, Ford V8's aren't all about 302's, 351's and 460's which is what most people equate to when talking Fords right?. I know Ford made a load of different displacement V8's. So I ask the question of you all, were any Ford V8's designed with the distributor in the rear? I'm mostly a Chevy person myself and just recently started working on some Fords and am unfamilar with all the different Fords V8's out there, so bear with me. Thanks.
Old 09-28-2003, 03:38 PM
jwtaylor jwtaylor is offline
jwtaylor is starting off with a positive reputation.
Well FE, 385, cleveland,modified, windsor,even flat heads had distributors in the front as well as the 232 v-6 that was in some early 80's trucks, inline 6 on the side but that doesn't count. So unless there is one I don't know of then I would say that fellow had one of those chevy transplants, why??? Interesting question, later
Old 09-28-2003, 08:40 PM
fordeverpower's Avatar
fordeverpower fordeverpower is offline
fordeverpower is starting off with a positive reputation.
I have never heard of such a thing on a ford.
Old 09-28-2003, 09:15 PM
FTE Ken's Avatar
FTE Ken FTE Ken is offline
FTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputation
Ford's common Y-block V8 had the distributor in the back.
Old 09-28-2003, 09:24 PM
There you go, learn something new everyday
Old 09-28-2003, 09:26 PM
FTE Ken's Avatar
On quick glance if you see it out of the corner of your eyes you do a double-take, thinking there's an off-brand engine under the hood.
Old 10-03-2003, 12:50 PM
Capone Capone is offline
Capone is starting off with a positive reputation.
Unless the engine was installed backwards....but then the truck would have to be front wheel drive?
just a possibility.
Old 10-03-2003, 01:11 PM
Capone I think we agree. My main issue was you cannot convince me that it is cheaper or even close to being cheap building a ford engine versus chevy using off the shelf parts. I will even take this a little further aftermarket wise it comes close but still the chevy has ford money wise and in my opinion neither one has a superior design head of any kind over the other, if you want to compare technology vs cost to make X amount of hp then again ford looses. I just cannot understand for the life of me why ford feels that it demands the prices they ask for off the shelf parts, its ridiculous and the aftermarket supports this as well even more ridiculous. If it weren't for the 302 craze a person would be insane to even attempt to throw money on a sbf and even think in terms of budget it would be more like restoration money can you imagine the prices if the 302 mustang craze never happened? As mentioned by others if you take ford and chevy heads of the same compression and flow along with the same cam profile you are gonna get the same amount of hp/tq give or take a little, and you can bet the chevy would be a whole lot cheaper. Again I agree with what you say and I think we are close on opinions, but when it comes down to the arguement over which is better you cannot convince me ford made anything special with the 96 motors down versus chevy, and when it comes down to which is cheaper that adds injury to insult, because ford loses. Later
Old 10-03-2003, 04:00 PM
71FoMoCo's Avatar
71FoMoCo 71FoMoCo is offline
71FoMoCo is starting off with a positive reputation.
Y-Block Pics
Here are a few Y-Blocks. I believe they were fairly common in Thunderbirds back in the day...
Old 10-05-2003, 06:56 PM
1975 f150 360 1975 f150 360 is offline
1975 f150 360 is starting off with a positive reputation.
i was just in the junkyard today and believe it or not i found an old ford truck looked like it was in the early 60's it was a bigger ford truck i popped the hood and there was a red ford mottor with the distributor in the back it said FORD in big letters on the valve covers so yes there are fords out there with the distributor in the back
1875 ford 360
Old 10-05-2003, 08:00 PM
the ol 292-312 Y blocks eh?....haven't seen one of them for a looooong time
Old 10-05-2003, 08:52 PM
kermmydog's Avatar
kermmydog kermmydog is offline
kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.
was just at the "Super Run 03" in Henderson Nv. Next door to Las Vegas And saw a few in fact 57 T-Bird with 312 2-4s. Haystacks no less.
Old 07-05-2014, 06:33 PM
flowney's Avatar
flowney flowney is offline
flowney is starting off with a positive reputation.
Quote:
Yes, indeed. I used to drag race with one of these dual four-barrel 312s in the late 60s - early 70s. Another fellow had the supercharged 312.
Back in that day, NHRA set up stock classes based upon a ratio of advertised horsepower and curb weight. The trick was to find a combo that was 1) on the edge of a class and 2) based on a grossly underrated horsepower figure. Chevrolet was extremely modest in advertised horsepower claims but these two Ford 312s were also lowballing their horsepower.
Old 07-06-2014, 09:05 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Quote:
Well mister cheapskate chevy guy, you try and build a SBC with late '80's early '90's parts and tell me how many engines you need to collect before you find castings that aren't cracked and/or full of poorly melted recycled material. You won't find thin wall castings or recycled material in any Ford castings of this vintage so are you factoring that into the cost? And why is being the absolute cheapest the deciding factor in building an engine? I simply don't buy the argument that it is significantly cheaper anyway, yes you might be able to do it for $200-$300 less but what's that in the big scheme of things.
Old 09-02-2014, 01:06 AM
krooser's Avatar
krooser krooser is offline
krooser is gaining momentum as a positive member of FTE.
Quote:
That knucklehead hasn't visited this joint for 8 years… good riddance.
Sync 4.6 Update issue blhamon 2009 - 2014 F150 15 12-27-2016 09:27 AM
1998 F150 4.6L that smokes when starting up Shorty2313 Modular V8 (4.6L, 5.4L) 2 12-16-2015 07:35 AM
I'm backkkkk!!! armydude Excursion - King of SUVs 7 08-15-2015 07:11 PM
New Guy have a 2005 V 10 Cool1 Modular V10 (6.8l) 2 04-10-2014 09:32 PM
How to fuel injection swap to carburator? f150cobrajet Fuel Injection, Carburetion & Fuel System 3 06-24-2002 08:06 PM
Tags
1957, back, block, chevy, disributor, dist, distributer, distributor, distributors, engine, engines, ford, motor, rear, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
