limited slip rear end
Back to my 2 w/d, '82' F-150 project truck. I've decided to stay with the existing 300-6, 4 speed combination. However, I do want to add a limited slip. I have what I believe is a 9" rear end (the gears are accessed through the front of the housing). If that isn't neccessarily so, let me know. The axle code is '15' which my Chilton doesn't even list for '82'. But for "83' it is listed as a 2.73, which seems about right ( it's real tall ! ). Unfortunately, I don't have any idea what's involved in replacing a standard rear end with a "limited slip". Also, will it be any more complex if I change ratios at the same time? I've gotten the impression that the 9" is pretty simple to change gears ( why NASCAR uses them ). Can I order a Ford limited slip from a wrecking yard, ready to go in the axle, or is it more complicated than that? Thanks for your help Guys! Halibut4
KevVer
1997-2006 Expedition & Navigator
23
08-15-2010 06:38 PM
Halibut4
11-03-2003 03:12 AM
