6.0 Liter Fuel Economy - Ford Truck Enthusiasts Forums
View Poll Results: What is normal fuel economy for a new 6.0 liter diesel ???
This pole has relevance to you? 42 67.74%
Fuel Economy of F250 6.0L diesel, who cares? 8 12.90%
The right question was asked? 7 11.29%
The right responses were obtained? 5 8.06%
Voters: 62. You may not vote on this poll
Old 09-28-2003, 12:03 AM
shamblin123 shamblin123 is offline
shamblin123 is starting off with a positive reputation.
Perhaps someone can help me out with a technical question about my F250 6.0L Truck. I put 35" LT315 75R-16 Toyo Cross-Country tires on my truck when it was one day old. I have about 7000 miles on it so far. The digital LED temperature/fuel-mileage/miles-to-empty guage shows I'm getting only 10-miles per gallon. If that is close to normal or actual, then I feel ripped off to get such horrible gas mileage. I was expecting around 13 to 15 mpg new and 18 to 20 mpg after about 35,000 miles (break-in).
I'm stumped, and so is the shop foreman at the Ford dealership. They can't reprogram my truck's computer because Ford's computer program software only goes up to size 285 tires. I'm just wondering if my tires are a 'big' contributer to my lousy fuel economy? Is 10-MPG normal for a new 6.0 liter diesel truck? I'm sure that the digital fuel economy readout may be somewhat skewed by the larger tires, but I can really tell that I'm sucking the fuel down.
My brother has a Black F250 7.3 liter diesel that looks almost identical to mine. However, he gets 17 mpg with his truck. Is there a solution to my delimna of lousy fuel economy? Is this normal? Everything on my 6.0L is completely stock with the exception of the 35" tires I mentioned and I also added a leaf to each 4 corners which raised it up about 2.5 to 3 inches.
Thank all of you for your comments.
Scott
scottshamblin(No Email Addresses In Posts!)
Old 09-28-2003, 04:34 PM
Skee Skee is offline
Skee is starting off with a positive reputation.
Stock tires 265 19.7 country roads
Skee
Old 09-28-2003, 06:18 PM
eharman eharman is offline
eharman is starting off with a positive reputation.
LT265's , stock, 17.6 mpg local driving.
Old 09-28-2003, 10:21 PM
smcdonn smcdonn is offline
smcdonn is starting off with a positive reputation.
265's, stock, runnin on the speed limmiter for almost a whole trip with a 16foot trailer full of 4 wheelers got about 12mpg. going easy unloaded I get about 15-16. Tires can make a fairly good change in fuel milage but surley the diesel doesn't notice them that bad. try an intake and an exhaust and see if that will get it up
Old 09-29-2003, 01:21 PM
jwdeats jwdeats is offline
jwdeats is new and has a neutral reputation at this point.
4x4, Crew Cab, Mixed Driving 70% local, 30% highway, I get 15.5 mpg. Stock tires.
I drive pretty conservatively, but I stomp the gas once every third day or so just to feel the rush of accelaration.
Old 09-29-2003, 01:31 PM
amacki4353 amacki4353 is offline
amacki4353 is starting off with a positive reputation.
F-350 SRW Crew Cab Fx4 6.0 King Ranch w/ 8000 miles average all miles driven 17.0 mpg. Would expect this to improve as mileage increases on the truck.
Old 09-29-2003, 05:53 PM
Daryl Hunter's Avatar
Daryl Hunter Daryl Hunter is offline
Daryl Hunter is gaining momentum as a positive member of FTE.
I have a stock California model with the 5 speed transmission and 3.73 gearing. The truck now has 13000 miles on it.
Unloaded on the highway I have seen over 20 mpg driving at 75+ but average around 17.5 mpg on general highway use.
In town commuting 4 miles to work and back I get around 13 mpg because the truck never really gets warmed up or into high gear for any length of time, plus I climb a 400+ foot hill on the way.
I tow a 30' Weekend Warrior trailer with a typical truck and trailer gross weight of 18000 to 20000 lbs depending upon the number of toys and gals of water in the tanks.
On a trip this last weekend from San Diego, CA to Pinetop, AZ and back, I averaged 8.66 mpg. This was towing at speeds of 65 to 75 mph. As the speed increased, the mileage decreased - most likely due to the increased wind drag on the trailer.
I've seen over 10 mpg towing the trailer on some segments, but over the course of most trips, this mileage seems about par for towing this trailer.
Old 09-29-2003, 06:15 PM
emilbanks emilbanks is offline
emilbanks is starting off with a positive reputation.
I have stock tires and less than a thousand miles and Im getting 17.5 MPG.
Old 09-29-2003, 09:17 PM
Kinda looks like the handshaker transmission gets better mileage than the put in gear and stomp on it
transmission.
Skee
Old 09-29-2003, 10:28 PM
myst myst is offline
myst is starting off with a positive reputation.
My 6.0 has 295 tires with no cat or muffler and i am getting between 17 and 20 mpg, auto 3.73 rear
Old 09-30-2003, 11:24 AM
Steven@nd's Avatar
Steven@nd Steven@nd is offline
Steven@nd has a very good reputation on FTE.Steven@nd has a very good reputation on FTE.Steven@nd has a very good reputation on FTE.Steven@nd has a very good reputation on FTE.
Why not calculate the actual mileage yourself?
Next time you fill up, reset the trip odometer to zero. When you fill again take the miles and divide them by the gallons of fuel.
MPG = Miles/Gallons
Just an idea...
Old 10-01-2003, 10:52 AM
Steven,
I was under the impression everyone was calculating the mileage using your technique. That is how I derive mileage, anyway. On my truck I didn't get that fancy computer thing with the display. I am amazed that some trucks get over 20. I only got about 17 on a highway trip. Maybe the air in Texas is too thick.
Old 10-01-2003, 01:39 PM
Colorado-native Colorado-native is offline
Colorado-native is starting off with a positive reputation.
6.0L fuel mileage
shamblin123
Here's the story on your 35 inch tires and fuel mileage.
I just measured the rolling radius on my stock 265s at between 15 1/4 and 15 5/16 inches which translates to 8 feet per revolution or 660 revolutions per mile.
Your 35 inch tires will have a rolling radius of around 17 3/16 inches depending on inflation pressure which translates to 9 feet per revolution or 587 revolutions per mile. For each mile your odometer registers, you have actually traveled 1 1/8 miles - 8 miles on the odometer equals 9 miles traveled. That could account for a 12.5% fuel mileage discrepancy.
However, that is not the whole story. It takes more energy to overcome the rolling resistance of the wide footprint on the road and probably more energy to just turn the increased mass of your tires. Lower inflation pressures will increase the rolling resistance. You have also increased the frontal area for increased wind resistance - larger tires being forced through the air and a raised profile. The air doesn't flow as freely under the vehicle as around and over the body due to turbulence from all those projections underneath.
Wind resistance is no small issue. I had an E350 Van that got in the neighborhood of 16 MPG at 45 MPH and dropped to about 10 MPG at 75 MPH.
Many delivery trucks use skinny high-pressure tires to overcome rolling resistance.
Energy used equals fuel burned!
F250 6.0L 5 speed auto XLT extended cab, Short Box 4X4. 18 - 19 MPG empty mountain highway miles over 10,000 - 12,000 foot passes and 12 - 13 MPG towing a 6000 pound trailer over two 10,000 foot passes.
Old 10-01-2003, 02:18 PM
coolbeans's Avatar
coolbeans coolbeans is offline
Wyoming Chapter LDR
coolbeans has a brilliant futurecoolbeans has a brilliant futurecoolbeans has a brilliant futurecoolbeans has a brilliant futurecoolbeans has a brilliant futurecoolbeans has a brilliant futurecoolbeans has a brilliant futurecoolbeans has a brilliant futurecoolbeans has a brilliant futurecoolbeans has a brilliant futurecoolbeans has a brilliant future
What has been said so far, is true, also, it may be helpful to change your gears to get you back to 3:73's (if that was your stock ratio).
Mine, on stock 265's gets 20.5 mpg @ 77mph. Towing my 29ft 5'er with my 2 place ATV trailer taggin along,(see my camping gallery), cruise set at 75-77 mph, i get 13 to 14mpg.(there has been times I've got that @ 65mph, oh well) This is a Canadian model & I now have 6300 miles on it since new. Born on 1-24-03.
Old 10-01-2003, 08:58 PM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
Forgive me, but what do you expect? If you put on oversized tires, it is naturally going to make the engine and the transmission work harder. My suggestion, get a chip or a programmer to give yourself a little more muscle to make up for those tires. An exhuast system wouldn't hurt either, every little bit helps. Besides, your truck is nowhere near broken in. That and the overhead console is almost always off by a couple points when it comes to the gas mileage. It shows the average miles per gallon not what you're actually getting. Calculate it yourself, you might a difference and then again you might not. Don't always rely on the console. I hope this helps in one way or another.
Loss of 1 MPG after 60k service tc0nn Oil & Lubrication 6 01-30-2017 11:27 AM
2011 fuel economy gas and diesel boblamp1 1999 to 2016 Super Duty 76 03-17-2016 05:45 AM
Fuel Economy Decrease with General Grabber LT Tires aeroskies 2009 - 2014 F150 20 12-14-2013 11:06 AM
Fuel economy for 2004 6.0L markwiebe 6.0L Power Stroke Diesel 12 12-01-2009 09:21 PM
SOLUTIONS PLEEZ !! 6.0 Liter WITH POOR FUEL ECONOMY ?? skigalini 6.0L Power Stroke Diesel 30 12-22-2003 08:01 AM
Tags
135, 2007, 60, 60l, diesel, economy, f250, ford, fuel, gallon, gas, liter, lose, mileage, miles
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
