Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
New! Use your Facebook to securely log into this site, click logo to login
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-13-2001, 12:16 PM
edfan edfan is offline
edfan is starting off with a positive reputation.
Instrument cluster for 1988 F250 ?
I have a plain jane F250 with manual transmission. I'd like to put in an instrument set to track the usual stuff such as tachometer, oil pressure, water temp, etc. Can anyone recommend a set and a source to get it? I have no idea if such options were available when the truck was new. I suppose I'd have to have sensors installed in the engine - how risky is that?
  #2 (permalink)
Old 07-13-2001, 09:48 PM
axlehop26 axlehop26 is offline
axlehop26 is starting off with a positive reputation.
I can answer one question for you - they definitely offered a cluster with tach, water temp, charge and oil pressure in '88, and any cluster from 87-91 would work, so you should be able to find one somewhere.
  #3 (permalink)
Old 07-14-2001, 12:59 PM
charlez's Avatar
charlez charlez is offline
charlez is starting off with a positive reputation.
search through http://www.car-parts.com
__________________
1993 4.9 5-spd 4x4
  #4 (permalink)
Old 07-14-2001, 01:18 PM
Pastmaster Pastmaster is offline
Pastmaster is starting off with a positive reputation.
__________________
1993 F-150 2wd 302
1996 F-250 2wd 460
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive -
Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
