Exhaust (cat) - Ford Truck Enthusiasts Forums
Exhaust (cat)
Old 12-31-1969, 07:00 PM
Guest
Posts: n/a
Exhaust (cat)
Old 07-16-2001, 04:42 PM
gui88ford's Avatar
gui88ford gui88ford is offline
gui88ford is starting off with a positive reputation.
Exhaust (cat)
I have one question......if i take off my cat from my truck will it cause any problems or should i take it off and "ream" it out
Old 07-16-2001, 04:48 PM
seebeew's Avatar
seebeew seebeew is offline
seebeew is starting off with a positive reputation.
Exhaust (cat)
If you think you can pass emmisions inspection without the
cat(s) ream em out!!!
-Chris
Big Red Ticking 92 F150
Tick,Tick,Tick,Tick,Tick,Tick,Tick,Tick
Old 07-16-2001, 05:18 PM
RGAZ RGAZ is offline
RGAZ is starting off with a positive reputation.
Exhaust (cat)
What year is your truck?
The year will determine the OBD system it uses and will tell you if the cats operation is monitored or not.
Randy
Old 07-16-2001, 07:26 PM
gui88ford's Avatar
Exhaust (cat)
my truck is an 1988 ford f-150.....it has a 302 that is bored and stroked to a 357......i have flowmaster exhaust on it and one "cat".....hopefully that is what you need....thank you for the information
Old 07-16-2001, 09:21 PM
Pastmaster Pastmaster is offline
Pastmaster is starting off with a positive reputation.
Exhaust (cat)
My 89 has complete dual exhuast, and the convertor and preheater were removed. I haven't seen any problems except for during WOT the check engine light comes on intermitently.
Old 07-17-2001, 04:07 PM
Exhaust (cat)
88 doesn't monitor the cat. It can be removed.
There is a little to worry about dealing with no backpressure and exhaust reversion, but it sounds like you aren't too worried about that.
The truck should run fine with no cat. Just plug the air pump tube that is between the cats if you remove them completely.
Heck you might as well remove the whole air pump system to the heads and exhaust.
Randy
Old 08-23-2012, 12:39 AM
FORD-or-Die's Avatar
FORD-or-Die FORD-or-Die is offline
FORD-or-Die is starting off with a positive reputation.
i have a 94 f150 5.0 4x2 302ci, need a new cat and exhaust any good brands on cats and whats a good size exhaust pipe?
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 04:27 PM
Can someone explain this to me? 1987 - 1996 F150 & Larger F-Series Trucks 11 03-09-2016 01:40 PM
ooops Aerostar 5 01-14-2015 04:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 07:14 AM
Gas Guage Stuck 1987 - 1996 F150 & Larger F-Series Trucks 4 02-20-2014 07:51 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
