88 F150 302 No Fuel Pressure
My 88 f 150 has no fuel pressure at the rail. i can hear the pump behind the seat running but not the one in the bed. it used to take this fits like once a year or something but usually i waited a week or 2 and then it would start. i have replaced the fuel p in the past trying to correct the problem. i have been told there is a short in the wires going to the back pump. how can i see if this is true? how do i look for a short and how do i replace it? thanks
on
1 Post
on your truck you have three pumps one near the cab of the truck (this is your high pressure pump ) and two pumps in the tanks if you have duals or just one in the tank if you have a single tank.
checking the voltage at the rear pumps is a start and for the fitts you say it has i would also replace the fuel filter. the pumps in the tanks are know to have shorts and failures.
I am currently looking at converting the fuel system on and 87 f 150 to the two pump design on the 93- 96 f 150..
