351 Windsor specs - Ford Truck Enthusiasts Forums
351 Windsor specs
Old 09-25-2003, 11:59 PM
94GTMustang 94GTMustang is offline
94GTMustang is starting off with a positive reputation.
351 Windsor specs
Can anyone tell me what the stock compression ratio is for a 1995 F-150 with a 351 Windsor? What is the stock combustion chamber volume? Hope someone knows, thanks.
Old 09-26-2003, 12:18 AM
fordtrks4fr fordtrks4fr is offline
fordtrks4fr is starting off with a positive reputation.
8.8:1 340 ft lbstorque@3200 240 hp@4200 california had less hp&torque that year according to a chart in chiltons. i am guessing stock still had the 69cc heads that year.
Old 09-26-2003, 05:12 PM
ExcellentRed ExcellentRed is offline
ExcellentRed is starting off with a positive reputation.
isn't that a little high for a stock windsor? I though its peaks were 300 ft lbs at 2800 and 200 hp at 3800
Old 09-26-2003, 10:56 PM
pfogle's Avatar
pfogle pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
I thought it was 210hp and 325 ft lbs of torque.
Old 09-27-2003, 02:44 AM
i saw a chart in chiltons truck manual. i think that was the listing for the calif sold truck. i dont know only typing down whats in the book.
Old 09-27-2003, 10:15 AM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
Moved to the 351 forum. This doesn't have anything to do with the truck, just the engine, so it belongs here.
Old 09-27-2003, 07:17 PM
I suppose there should be a way to figure it out if you know the mass of the truck and the time it takes to accelerate. Power is the change in energy divided by the change in time, so if you could write it as m*(v1^2-v0^2)/(t1-t0). But then again, that doesnt take in account gear ratios and such...I'm sure some engineer could help me out!
Old 09-27-2003, 10:20 PM
fordeverpower's Avatar
fordeverpower fordeverpower is offline
fordeverpower is starting off with a positive reputation.
Its 210hp and 325tq the 240hp and 340tq is the lightning motor.
Old 09-06-2008, 04:52 PM
monkei's Avatar
monkei monkei is offline
monkei is starting off with a positive reputation.
1995 vinH MFI: 210hp@3600 325lb/ft@2800
1995 vinH SFI(CA/e40d/maf): 205hp@3600 330lb/ft@2600
1995 vinR MFI(lightning) 240hp@4200 340lb/ft@3200
This is direct from Chiltons, look at the notes. '95 CA SFI trucks had more torque at a lower RPM and 5 less hp at the same rpm as the MFI trucks of the same year. Hard to compare the lightning stuff because the engine speeds are a decent amount higher. They all have the same compression (8.8:1) but the lightning has a different cam and the gt40 style intake.
Old 09-18-2008, 09:57 PM
themoparkid's Avatar
themoparkid themoparkid is offline
themoparkid is new and has a neutral reputation at this point.
Quote:
^ he is correct.
you fellas can check with the vin letter. it tells you in the chilton book.
Old 09-19-2008, 08:01 AM
cjben cjben is offline
cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.
thread mining at it's finest!!
Old 10-21-2009, 06:53 AM
broncoguy83 broncoguy83 is offline
broncoguy83 is starting off with a positive reputation.
i have a 83 bronco with a 351 windsor. i was curious as to if i could take the heads from my 78 351 modified and exchange them with the factory windsor heads? if so, what kinda problems and/or challenges am i faced with?. is it really worth my time and money?
Old 10-21-2009, 08:35 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Quote:
You should have started a new thread man.. it's a legitimate question that's not really related to this old thread.
Installing 351m heads on a windsor block is possible but they're likely to perform worse because '78 was a smog year and these heads will have large combustion chambers so compression will drop. And you're going to have a problem finding an intake to fit, so overall this is a bad idea. If you want more output from the windsor simply put a cam in it and install an aftermarket intake and exhaust, that's the short route to 300hp.
Old 10-21-2009, 02:46 PM
what cam should i run with a edelbrock performer dual intake?
Old 10-21-2009, 04:56 PM
Conanski's Avatar
Comp cams 35-238-3.
351 windsor union bubba 1973 - 1979 F-100 & Larger F-Series Trucks 8 04-18-2011 02:41 AM
#51 windsor cam in 302 first today Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 6 06-10-2010 06:02 PM
351 Windsor mods newbie616 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 47 02-12-2009 04:12 PM
351c - 351w - 351m differences gettler 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 42 05-25-2004 11:25 PM
351 Windsor 93bronco 1978 - 1996 Big Bronco 2 12-23-2000 01:25 AM
Tags
1984, 1995, 351, 351w, 95, compression, engine, ford, settings, spec, specifications, specs, torque, windor, windsor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
