Symptoms of a throttle position sensor going bad? - Ford Truck Enthusiasts Forums
Old 09-25-2003, 09:46 PM
Big Daddy Braddy Big Daddy Braddy is offline
Big Daddy Braddy is starting off with a positive reputation.
Lately I have had an occasional shudder from my truck. 93 f-150 4x4, 302 auto, 3.55 regular cab. It doesn't seem to have any certain conditions in order for it to happen, it just happens randomly. Sometimes at highway speeds and sometimes at low speeds. It feels like it is running out of gas, but the rpm's never change. Any ideas?
Old 09-26-2003, 02:26 AM
c96drumm's Avatar
c96drumm c96drumm is offline
c96drumm is starting off with a positive reputation.
Just a shot in the dark here, but maybe the EGR is acting up. Sticking, or something. Have you pulled the codes?
Old 09-26-2003, 12:15 PM
tsheriff tsheriff is offline
tsheriff is starting off with a positive reputation.
MIne would ping bad pulling long hills and have no power.
Old 09-26-2003, 10:35 PM
HardScrabble HardScrabble is offline
HardScrabble is starting off with a positive reputation.
How did you figure out that your TPS was bad?
Old 09-27-2003, 02:38 AM
Superdave Superdave is offline
Superdave is starting off with a positive reputation.
Big Daddy Braddy
Is it the famed torque converter shudder?
Old 09-27-2003, 10:25 AM
alabamabuddog alabamabuddog is offline
alabamabuddog is gaining momentum as a positive member of FTE.
Mine did that and I got better gas
Old 09-30-2003, 07:36 PM
TPS
Where can I get the codes pulled? What does it cost? One other thing that happens is that when it is first started, it will begin to idle fine and then begin to sputter and die if I don't tap the gas pedal. Also, if it is in gear and I get out of the gas quickly it will go dead. This has been happening for quite a while but I just found this site so I thought I would try here first.
Old 09-30-2003, 10:33 PM
Vanhecht's Avatar
Vanhecht Vanhecht is offline
Vanhecht is starting off with a positive reputation.
get a code reader at a parts store for 30 bucks, also if you have a chiltons manual it will tell you how to check your tps with a multimeter...couple things to try i guess...
oh, also, does your check engine light come on? if not i dont think youll be pulling any codes....
Old 09-30-2003, 10:43 PM
c96drumm's Avatar
You CAN have codes with no check engine lights. If it lights up, you do have codes. If not, maybe you have codes. Only way to tell is to pull 'em.
Old 10-01-2003, 08:02 AM
dfawvor dfawvor is offline
dfawvor is starting off with a positive reputation.
Thumbs down Same problem
Big Daddy-
I'm having the same problem as you describe. Too busy with other projects to mess with it. Eager to hear what you determine is causing the problem with your vehicle.
Old 10-03-2003, 09:04 AM
Thumbs up Maybe the MAP sensor
Big Daddy- I was getting the same problems at start up as well as the stutter AND pinging on excelleration. Last night bought a $25 code reader from Wal-Mart. The KOEO test indicated code 22 (MAP Sensor out of range). Went to parts store, bought new sensor (about $60). The sensor (on my 88 F-150) is on the left side of engine compartment on the firewall. Just 2 screws holding it on. Replaced and the truck runs like a champ! No more stalling during startup and no more pinging AND MORE POWER!
dfawvor
Old 10-03-2003, 11:03 AM
ksvtwin ksvtwin is offline
ksvtwin is starting off with a positive reputation.
My '93 f150 is doing the EXACT same thing. stutters a little at ramdom while driving, wants to suddenly die when first started up, and stalls when you step on the gas. Reading codes with a sweep meter is something i've always struggled with. maybe i should go to walmart and look for that code reader. I'm going to check several of the sensors this weekend with a good voltmeter too.
Old 10-03-2003, 08:46 PM
Thanks a lot fellas!
I appreciate all the tips. The check engine light does not come on, but I will try some of the things you suggested.
Old 10-04-2003, 09:38 PM
shutterman shutterman is offline
shutterman is starting off with a positive reputation.
dfawvor,
Was your check engine light on when you decided to buy a
code reader? Just wondering. I am having the same problem
you guys are having. Sounds like I need to buy a code reader!!!
Thanks,
shutterman
Old 10-06-2003, 08:48 AM
As I mentioned above, my truck was having the same problems. My check engine light never came on. This weekend, I jumped the self test terminals as per the Haynes manual. Then I turned the key on and watched the "check engine light" flash. It showed a code 23 twice and then it showed (i think) a code 66. those are both codes for the throttle position sensor. I borrowed a good digital volt ohm meter from work. I checked the voltage into the unit and it was 5 volts like the book said. The voltage output of the unit was also as per the book. Then I disconnected the unit and checked the resistance as it said to inthe book. The resistance should be within spec and a smooth transition. It was mostly within spec but was not smooth. It was very jumpy and the numbers bounced from high to low and back to high. I'm sure I've found the problem and I'll be putting one on tonight. I just wanted to share this with everyone for information purposes. Maybe it will help someone else. I love my '93 F150........240,000 miles on it and still going strong! Kent
Need Help: 2006 F250 Powerstroke. sstellmon 6.0L Power Stroke Diesel 2 03-12-2015 12:25 AM
Transfer Case Knocking? SpencerS 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 01-05-2015 07:33 PM
Excursion Front end bouncing mkbishopsa Excursion - King of SUVs 10 08-06-2014 11:35 AM
4 wheel drive not engaging Rus01 6.4L Power Stroke Diesel 7 12-10-2013 04:03 PM
04 Stutter dcon12 6.0L Power Stroke Diesel 10 08-14-2011 07:53 PM
Tags
1992, 58, 58l, 93, accelerator, bad, f150, f250, ford, map, position, sensor, symptoms, throttle, tps
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
